AVS › AVS Forum › Audio › Speakers › Should I angle my surrounds down?
post #1 of 6
I know that the ideal location for the side & rear surrounds should be a foot or so above the listeners head but I can't mount my speakers that way since they will be in the way. I have to mount them near the ceiling which is about 5 ft above and 2 ft behind my head so my question is should they be angled out straight facing each other or downward directly toward my head?
post #2 of 6
Aim them at the listener.
post #3 of 6
Are they monopoles, dipoles, bipoles or some other iteration of multipolar speakers? If they're monopoles, definitely aim them at the listening position. If they're any other variety of multipolar speaker, you'll need to experiment to see what sounds best.
With dipoles, you want to sit in the "null" of the mid and high frequency drivers. Dipoles fire the mid's and high's away from the listener and towards the front and back of the room, (or the side walls if they're the rear surrounds). The listener hears mostly reflected sound, which makes the sound more ambient and spacious. It will take some experimentation to determine whether aiming the null at the LP sounds more spacious and ambient than with a straight forward mounting position. Most dipoles are designed to be mounted flat on the wall.
With bipoles or any other variety of multipolar speaker, it will also be beneficial to experiment. The best mounting position will depend on their dispersion pattern. Bipoles generally have a wide dispersion pattern and it may not make a big difference how you mount them. Other multipolar speakers can have limitless dispersion designs and the only way to determine how they sound best is to try them in all the possible mounting arrangements.
Good luck.
Craig
post #4 of 6
They are monopoles and since they are mounted with brackets I have the luxury of angling them. I will angle them toward the listening position. thanks.
post #5 of 6
I would recommend that they point across the room pointing @ each other.
Review my webpage ... INFO from Dolby Labs original Professional Encoding Manual & Consumer's HT webpage.
Check out my diagrams & "Aiming" text ...
Aiming
"Aiming surrounds straight across the room, not down at viewers, helps create a more open, spacious surround soundfield."
... originally posted on Dolby Labs Consumer HT 1999-2002 website.
The 2005 Dolby Surround Mixing Manual (PDF file) still recommends the same setup ...
2.3.5 Surround Speaker Location (pg. 2-10)
For installations using one pair of speakers for the Surround channel, place the speakers on the side walls approximately two feet behind the engineer's seating position and at least two feet above the engineer's head. They should point to a spot two feet above the engineer's head, as in Figure 2-16 (see attached image below. If four or more speakers are used, the same guidelines apply for each set of speakers. In any case, never point a Surround speaker directly at the listener or below their seating position.
I setup my six JBL S26's like a Mixing room in my 25' x 30' HT/family room!
After you setup your speakers, Calibrate your HT SPLs around you @ your 'sweet spot', then play one of your favorite DD/DS-5.1/6.1 DVDs!!!
Phil
post #6 of 6
Aiming monopole surrounds is necessary. Mine have to mount up near the ceiling as well and I've got them on movable mounts so I've played with them a lot. When facing straight out I've had people ask if they were even working. When I angle them down toward the listener (down and slightly in toward the room) I get solid surround sound. Surrounds may not work as hard as your fronts but their sound waves work the same way.
I've never played with dipoles, but they sound like they might be a better choice in odd rooms or configurations. Wish I had a large enough room I could put my surrounds on stands behind the couch...but that's not to be in this decade.
  Back to Forum: Speakers
