AVS › AVS Forum › Audio › Speakers › THX Ultra II Speaker experience?
post #1 of 2
Hey guys!
I'm helping out a local AV shop to move out and build a showpiece cinema. Dimensions of the room is yet to be specified but we would probably go with 32'(W) x 22'(D) x 10'(H) after acoustics and proofing. We're thinking of using either Klipsch or Snell Acoustics (XA 1900THX, SR30 THX) THX Ultra II systems. Power will most probably come from Crown XTi 1000s. The system will be mated with Dunlavy's DTS-20 subwoofer.
In your opinion, which would be a better choice?
We still have time to make the decision. We will move end of October.
Farhan Yassin.
post #2 of 2
I have a 5.1 setup with the THXUIIs and two RF-82s as rears in an unfinished basement. As for me, I cant get a perfect sound because I am in a 1200sq ft concrete room with. I should be able to start on my room in a few weeks. I am currently running off of a Deon 3806 but will soon have Crown amps as well. I believe they come on Friday. I decided to go with the XLS 402s instead of the XTis. I'll keep you posted. I hope to have my theater done by the middle of October.
  Back to Forum: Speakers
