AVS › AVS Forum › A/V Control & Automation › Home A/V Distribution › made a mistake on prewiring
post #1 of 8
Hi
I did a major remodel, and had some prewiring done. I only ran one coax and one rg5 to each room. My question is can I use the rg5 runs to create 2 or three rooms with hard wired ethernet ? Sorry for the dumb question. I have been reading all the posts for months, but obviously it did not sink in...Thanks
Jim
post #2 of 8
I assume that you mean Cat5 for ethernet. If so, you could get some small 4 port ethernet switches to create little mini-subnets.
Did you staple them done or something? You could use one to pull more through if not. I try to alway pull wire "loose" through walls and then attach a heavy string so in the future I can pull more.
post #3 of 8
I wouldn't worry. I strung miles of cate 5e and coax only to find out most of what I implement is wireless. I've only hooked up 1/20th of what I strung.
post #4 of 8
How far is the wire, how thick is it, did it go through studs, how big did you make those holes, etc?
Could you use it as a "pull wire", and pull through a few more runs?
post #5 of 8
thanks guys. The wire is pulled thru various rooms, and is pretty tight. What are the "some small 4 port ethernet switches to create little mini-subnets". That might be the way to go
J
post #6 of 8
I'm not sure exactly what you're trying to do but remember that an ethernet connection only uses 2 of the four pair of a cat5. You can actually get two ethernet connections out of a single cat5 wire.
post #7 of 8
Put network switches everywhere.
http://*******.com/3csvwk
post #8 of 8
Check all of the networking vendors. Linksys, D-Link, SMC, etc. They make 4 or 5 port switches. A 4 port would give you 3 additional connections from one input.
I have an 8 port switch in my office where I have only one RJ45 in the wall, but needed more connections. Great quick solution for a couple more ports.
  Back to Forum: Home A/V Distribution
