Originally Posted by FullOnShred
Nice. Coincidentally, my Sylvania uses real-time dubbing from HDD to DVD so maybe that is why it retains exact edit points.
Now, with the 3575 is it any easier to SET an exact edit point than it was with the 3455/37? This is another key point. My Sylvania has a far superior Editing Function that makes PLACING exact edit points very easy.
I appreciate the responses here. I am not ready to read that Dostoevsky Novel which is the 3575 Thread.
If I understand your question on "easier," I can select any frame in the video to start and stop a cut using the FF/REW buttons to get close, then the PREV/NEXT buttons to advance or go back a frame at a time. It's all "visual" however, and this is what you might have meant...there are no counters or display to show a specific frame number while looking for an edit point.
I decided to test my edited test title for "pauses" at edit points and found that RT dub leaves ~1-3/4-sec pause, consisting of 27 "odd" frames... 4 frames of still, 5 frames of black, then 18 frames of still again. A HS dub leaves a clean 0-frame cut but the pauses are 1.5 sec before finalizing and 3 sec after finalizing.
