AVS › AVS Forum › HDTV › HDTV Programming › DirecTV 2007 New HD Channels - First Wave anticipation thread.
DirecTV 2007 New HD Channels - First Wave anticipation thread. - Page 4
post #91 of 1793
Originally Posted by guffy1 View Post
Are you saying that theyve come out and fixed problems without you even having the protection plan?
Yes. They replaced an out-of-warranty HD receiver that had one tuner go bad for no charge. I even offered to let them simply ship me the box for self-installation, but they insisted on sending a tech to do the swap.
post #92 of 1793
I had a HD DVD from Directv and it was not operating correctly. In 3 days an installer came around and replaced the defective unit with a new HR20-700..zero charge. Afterall, it is leased from Directv and they should replace it (if they want my continuing business).
post #93 of 1793
Originally Posted by Googer View Post
It's speculative at this point, at least until D10 actually goes live, but from what I've seen, the thinking is that the current HD offerings will in fact be mirrored in MPEG-4 on D10. Sure it's a bit wasteful of bandwidth for now but it helps out people in situations such as yours and makes turning off the MPEG-2 HD's for Sunday Ticket a lot less painful - if someone calls up D* to complain about it once they're mirrored, D* just says "no problem, upgrade to an H20/HR20 and 5-LNB dish and you're covered, plus you get all the new HD".
I am hoping that at least ESPN/2 will be put up on D10 (in MPEG4). Football PQ doesn't seem to have the pop it had last year, and we've all heard the ravings of the LiL spotbeamers.
post #94 of 1793
Originally Posted by CPanther95 View Post
Second, you can also get a better view of a running back taking a handoff and making his initial cuts from behind - that doesn't mean that is the prefered view for television viewing of football.
Which is why they broadcast football from the sides but not tennis. There's a reason the end seats cost much much more than the side ones.
post #95 of 1793
I subscribe to the SD Sports package, so I wonder what about the RSN-HD's, will they be only available on the spot beams or will I be able to receive more then just "my one home RSN"?
post #96 of 1793
According to DirecTV officials, you should be able to get HD games of whatever sports package(s) you subscribe to.
post #97 of 1793
Originally Posted by Arkie View Post
I am less than 30 miles from you as the crow flies, and have considerably higher signals than you. with all but the first two transponders, which are 0's,
I range from 95-99......
you might want to check your dish alignment
What was wrong with his numbers? Is 95 going to look better than 85? And I wouldn't mess with it until the channels go live...things are constantly changing up there...
post #98 of 1793
That was my thought too. Reminded me of when my installer installed my new 5LNB dish. He had to put it on the peak of the roof instead of the bottom of the eave like the 3LNB dish. The installer told me I'd get a stronger signal and the picture would be a lot better. LOL!!!! Something that basic and the D* installer was clueless. He then saw my small $25 Phillips powered antenna in my window sill. I had it on Fox HD and it was around 7, and locally, that's Friends reruns in SD. He said "If you get a bigger antenna, one that says HD, Friends will be in HD". LOL!!!!
Moral of the story.....even folks that have HD sets and HD programming are at a loss on many things such as signal strength etc. I'll be happy if I get 95 on the new transponders..heheheh.
post #99 of 1793
Good evening guys:
1807 ETD 103b latest readings
01-08> 00 00 00 98 88 95 94 95
09-16> 95 95 94 96 95 96 na na
17-24> 80 na na na na 100 n na
Check Tr. 22 it has a 100% reading. This is the 1st time I have noticed that! Is this reading significant? Also I called D* and a CSR told me that 37 HD CH's will be activated/added next Wed. 19 Sep 07!
Later~!
post #100 of 1793
I concur. It is better to wait until we get programming. My numbers have been changing all day. Do no adjusting for several days.
post #101 of 1793
Well, as this Sunday began I had an average of 96 for the transponders on 103-b. As the day closes, I am down to about 94 as an average. We shall see what Monday brings in the way of adjustments. Did others gain or lose as far as signal strength this Sunday?
post #102 of 1793
I gained on some - lost on some. I'm not touchin' a thing until the dust settles and we see programming. And I may not change anything then, unless I start getting rain fade.
post #103 of 1793
They don't have Arkansas thunderstorms out there in Cali........Rain fade can be an issue here..........just trying to help a brother out......the difference between 95 and 85 here could be the difference in having a picture in a downpour or not.......
post #104 of 1793
WOOT!! I just jumped back on the boat today They wouldn't give us the DVR for anything less than $300, but we ordered the Sunday ticket and they gave us 4 months free of the Premier package. I guess we should be happy because they waived our cancellation fee (I switched to TWC a few weeks ago) History HD is the deal maker for me, it would probably take cable another million years to get all the upcoming HD channels on D*. I'm going to complain if the football games suffer from the same pixelation like last time.
post #105 of 1793
I just checked my signal strength for 103b and it varies from 22 to 50. Will I need to adjust the angle of my 5lnb?
post #106 of 1793
I think you have to. I get 97 on 101, 94-95 for 110 and 98-100 for 119. I am averaging 95 for all the 103b transponders. With ALL due respect if I were you I call the D* tech.
Good luck!
post #107 of 1793
Yes, 22 to 50 sounds low but...There are a number of things that affect signal strength for Ka-Band satellite signals. Ka-Band (20GHz) is different than Ku-Band (11GHz - what D* and E* use for their original satelliites). Rain fade is a significant Ka-Band issue but the satellite power can be adjusted to compensate for the fade in areas. A good reference paper (at least the summary) is at:
http://gltrs.grc.nasa.gov/cgi-bin/GL...TM-107534.html
http://www.kusat.com/P/ka/rain_fade.jpg
http://www.kusat.com/go.php?path=/ka/qa.php - not for Ka-Band TV but some interesting information
Another thing that can change your reception is how many times you're dividing the signal to the receivers, how long the cable lengths are and, of course, the alignment of the dish. The shape of the dish could also have a big impact, particularly with tracking 5 LNBs from one dish.
And, of course, this satellite is still undergoing testing and they could be changing TP strengths as part of the test. Large jumps in TP strength during tests can occur.
So, just because someone says that they are getting 98 and someone else has 95 doesn't mean a thing. However, as previously mentioned 22 is *probably* something to check.
post #108 of 1793
I'm getting 81-91 here in Greenville, SC. I typically get 96-100 on the other sats..
post #109 of 1793
I wouldn't worry just yet. I was getting 87-90 pretty consistently and now I'm getting:
0 0 0 96 89 95 87 0 93 95 91 94 95 96 94 98
post #110 of 1793
I don't know what football games you're talking about, but only some RSN, and BTN games are going to be going to be going over mpeg4.
post #111 of 1793
It looks like they are testing/tuning the individual transponders. I'm getting very consistent readings now across the active transponders which wasn't true earlier today.
post #112 of 1793
Translation: Welcome back to the pixi party my friend! Glad to have you!
Actually, depending on how many subchannels your local channels are running, your going to get pixelation reagardless of MPEG-2 or MPEG-4 transmission. Its not neccessarily the fault of D* when you are seeing those pixelation problems, although their MPEG-2 bit starving definitley doesent help matters any.
post #113 of 1793
It probably will need to be adjusted. But people are getting widely different readings right now, depending on the individual transponders and where they live. The satellite is still being tested and tweaked, so I would wait until the new channels actually go live.
post #114 of 1793
I've had 2 DirecTV installers come out to change my dish to the 5LNB type. Both have said I have too many trees in the way that I won't be able to get the "new" satellites. (Thus no new dish yet!!)) If I can get sat 101 and sat 110 all year shouldn't I be able to pick up sat 103 OK?? I do have a problems picking up sat 119 because of trees in the way but in the winter when the leaves are off I get good signal strength. They are also reluctant to place the dish on the chimney chase. I have mounted the last 2 myself but I think the new dish maybe a bit more critical in "aiming". Am I correct in assuming the "newer" satellites are higher on the horizon than 119??
post #115 of 1793
The 103 sats are between the 101 & 110. So if you can get the 101 & 110, you should be able to get the 103. Other new HD sats are/will be at 99°. How is your clearance to the left of where the dish is currently pointed?
They are all circling the equator at the same "height" - some 22,000+ miles out.
post #116 of 1793
I called for a dish realignment, because 103 B was only gettting around 35.....well the CSR asked me to check 101 and the others, all of which were in the low 90's....then she twice put me on hold, the second time she told me she was getting a confirmation...seems 103B is not going to be used for the new HD (according to what she was told by two different people), they are going to park some of the lighter traffic ahnnels on there, she did say if I had a problem on Wednesday seeing the new HD channels to call back, but right now they said I will be fine....so this should be interesting. I told her to make sure she put me on hold, and was adamant about it...
post #117 of 1793
That is just an insane comment by the CSR. It really is wild. ha-ha.
The new MPEG 4 national HD channels will be on 103 b. No question.
post #118 of 1793
I know....I thought I would share....
post #119 of 1793
I set-up a new receiver (H-20) today and am not getting anything at 99 degrees (it listed n/a in the signal strength meter). We have a 5-LNB dish and didn't have this issue when setting up any of our other (3) HR-20 receivers. Could it be tweaking or is there a problem?
Also, when I logged on to my directv.com account to activate the receiver, the "My Programming" area showed "Starz HD" and "Cinemax HD" as well as "HD Access" ... A few minutes later that was gone and the regular, current information was back. By the by, we are premier customers who also get locals and the current HD package.
post #120 of 1793
I was under the impression that sat 119 was lower in the horizon than 99 101 103 and 110.
Are they all the same "height" as I look to the southwest? I live just northeast of Atlanta GA.
  Back to Forum: HDTV Programming
This thread is locked
