Is there any possibility to display the currently used video- and/or audio-codec & bitrates, as the Toshibas (codecs) and Sony's PS3 (codecs+bitrates) offer? Would be a nice feature, I really miss this on the BD-P1000 ...
It's great that it has 7.1 analog outs. It'll interesting to see if it will onboard decode DTS-HD MA, and if it outputs 8 channel PCM (for decoded TrueHD or DTS-HD MA) over HDMI. That would be a nice feature.
The limitation of 256 MB internally seems to be as far as any dedicated BD players does to date. I don't believe any of the other dedicated players have more (as well as an Ethernet port).
The PS3 has a total of 512 MB memory, though I do not know how much is dedicated to BD downloads functions.
What about bass management? Specifically, is there a variable crossover, or is it fixed at 100Hz like the 1200? Are there speaker distance settings for delay?
It also has a hard drive which can be used for persistent storage. Most models also have the memory card slots as well.
I really think next year's Sammy will be a great final player. Hopefully we get loads of copycats so the price falls significantly as well. For now I'll still keep the PS3 for BD and wait for a better HD DVD player. By next year we should know if the PS3 will decode DTS-MA so I can decide if I should buy a new HD DVD only player or a DF player.
There are pictures too(oooo). Please don't post the review on the forum (its copyrighted).
The HD Guru
Have you had any chance to test (or at least view) the speaker management setup? Is it the old one we know from Samsung (which renders the analog outs pretty much useless)? Or is it a speaker management you can work with?
Its glossy on the front, top and sides like a Drakes " Ring Ding" (for those of you in Drakes Cakes territory.
From a Samsung spokeperson "After the firmware upgrade, the player will support both HDMI and analog output for not only Dolby TrueHD, but also DD+, dts-HD HR and MA."
The choices for speaker management are off/small/large and there appears to be options for the .1 subwoofer, but they were glitched on the pre-production sample.
Does anyone know if this player will output regular DVD at 1080p24?
Nothing on the market does that and it would not be useful anyway. The material on SD DVD is already converted from 24fps to 60fps on the disc. The ability to play 1080p/24 is merely to allow a source that is in 24fps to remain that way--as is the case for some hi-def discs and will be the case more often. It is NOT meant to take a hi-def source that is at 60fps and convert it to 24fps after the fact.
People were talking that the XA2 will convert to 24. Is this a benefit or true?
BD Java 2.0...what does this do in reality?? I find it annoying that I would have to connect the player to a modem (why not have a wireless modem built in) too much clutter being that my modem is in another room.
What will be the benefit of having the player hooked up to the internet? what will it allow me to do? download minor things that I have no time for?
I thought it meant the XA2 would get a firmware update to do 1080p/24, not upconvert SD DVD to that format. I don't know if it's even possible to do so.
