I recently posted this in the CMS setup sticky thread and I was wondering if anyone could help me understand this post:
Could someone explain this setup method or direct me to an expanation.
Originally Posted by robbyc30
On another subject, I beleive it was Tom that mentioned that my RGB levels (especially Green) were lower than should be necessary for a proper calibration on this unit. The reason they were so low was my method, posted on the forum quite awhile back, by Guy Quo. His method was basically, center Brightness/Contrast, set Red and Blue Offset too low and use Green Offset to set Brightness (make BTB match backround). Return Red and Blue Offsets to default. Then, set Red Gain to highest that doesn't cause clipping. Then use only the Green and Blue Gains, and the Red and Blue Offsets to calibrate. I've always assumed this was correct. I mean Guys knows what he's talking about...right?
Rob
Rob
