OMG (sorry for sounding like a teenage girl!) I got it. I hooked up the LG Blu-ray player (BD-570 - it's a piece of junk- doesn't play most blu-ray discs anymore.) I put in my CD-R burned from WMP and it wouldn't read the disc. I googled and decided to burn a CD-R (onto another brand of CD-R, Sony - the WMP disc was OfficeMax) using a program called CDBurnerXP. I changed the LG player's optical output to be "pass-thru" instead of PCM. And it worked! Not sure for the other players if the disc wasn't burned correctly, or if they simply weren't passing the cd audio through unaltered. Anyway, it's finally done- and I can hook my ~30 wires up to it knowing I won't need to unhook it again for a long time. I suspect considering it's age, there won't be any additional firmware updates. I had my last receiver for 18 years, hopefully if I don't have an issue with the capacitors that some have eluded to, this one will last me quite a lot longer.
I probably wouldn't have taken it to a service facility to be updated- right before 2.013 was released I did that and I ended up taking 3 half days off of work- the third trip was because the guy didn't get everything updated. I'm lucky to have brought the instructions for inspecting the firmware versions with me to pick it up the first time- otherwise I would have had four trips back and forth. Anyway, I wasn't willing to go through that again!
Thanks again for your help guys. Any chance Steve you can look up your EX.SSP value for me? Thanks! AL
I hope it doesn't die on me because of some cheap part failing!
What sub is it and how old is it?
