AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Official Pioneer Elite VSX-92TXH thread
Official Pioneer Elite VSX-92TXH thread - Page 3
post #61 of 1960
I know this may sound weird, but my 92 doesn't sound loud enough. I have my ps3 connected though optical/toslink and even playing movies bd/non bd I can turn it up to -18 and it still sounds somewhat quiet. I haven't done much configuration but remember my old onkyo was a lot louder. I have the 92 connected to def tech 7002's and remember it sounding a lot louder in the demo room. I know the store wasn't running any extra amps hidden away as its a friend of a friend. I just remember out of the box the onkyo was a lot louder..and they the onkyo was pushing some onkyo htib speakers.
post #62 of 1960
Originally Posted by therockscott View Post
I know that it depends on the codec. Say for instance that I'm listening to Casino Royale. Has uncompressed pcm and dd 5.1 track. On my player, I have dd as bitstream. When I'm watching the movie and going thru the audio, when switching between uncompressed and 5.1, shouldn't i hear a difference?
yes, there is a big difference between the PCM track and DD track on Royale. I do not know about your speaker setup, so I cannot guess on that. But there is a ton of background sounds you will hear on the PCM track and not on the DD track. The voices should have more clarity and dimension on the PCM too.
post #63 of 1960
How loud do you need it? I dont know how loud mine goes cus my neighbors will yell at me if I try. Unless you are playing your music outside in a field any of the current receivers should be too loud. You may have midnight on or some other setting is way off.
post #64 of 1960
I don't need it that loud, its just in the demo room it was a lot louder to the point of it almost being unbearable. Mine comes no where near that, and even at -15 when I have my parents over they cannot hear it upstairs. I tried some of the other settings and it was a bit louder, but I will play with it this week and see how it goes.
post #65 of 1960
I have the VSX 91 and feel the volume is low as well. To listen to a concert dvd I like it quite loud and I have to crank it up to +5 to 10 and even so its not that loud. Some sources are louder than others but even TV viewing I have it up to -5 depending on the channel. Why have -40 and lower if it cannot be heard?
post #66 of 1960
Why wouldn't you connect your PS3 via HDMI? You do know what this receiver is capable of on the audio side, right? You won't get Dolby True HD or 5 full channels of PCM using the optical audio connection.
post #67 of 1960
honestly I was trying to keep a fair playing field compared to my old onkyo. I will be connecting my hdmi up this week for more testing.
post #68 of 1960
Anyone try a new A35 to see if TrueHD or DTS Master llights up? I'd consider upgrading to a 92 or 94 if I knew for a fact it worked.
post #69 of 1960
tonight I tried hooking up the hdmi(just for audio since right now I have it connected to a non hdmi tv) and received no output. I even put it on all 3 different hdmi inputs just to see if audio was going through(i know video wouldn't work), but no luck. I know there must be a work around for this.
post #70 of 1960
There is a BIG difference but my 92txh is doing the dialnorm thing. So it takes that DD signal and boosts is +4. I would rather them leave that program out but I've been searching for HOURS trying to find a way to disable that function off but nothing. Even when watching HD cable, it's even gone as low as -7. So does anyone have a list of what receivers use dialnorm? Cause I'm seriously thinking about returning this receiver today if I can't find any answers or disable that function in the receiver.
post #71 of 1960
ill have to ask my fruend to see if he can find out about the dialnorm. When I turned off MCACC it was a bit louder when playing ps3. Does the MCACC notice if the speakers are close to each other and keeping thr volume down?
post #72 of 1960
Go into the MCACC through setup and look at the settings. Among other things, the MCACC will lower levels on each speaker, lower equalizer settings, set you speaker sizes to small and move trim levels down on your equalizer. All of these can make your system quieter. Go in and adjust them until Warhawk makes the people across the street think they are being attacked by Iraqis.
post #73 of 1960
Thanks. I REALLY like the receiver and I don't want to return it. Just hate DIALNORM.
post #74 of 1960
Is there a button on the remote(for 91 or 92) that will allow the disabling of the dialnorm?
post #75 of 1960
Thats wierd because MCACC set my front(Def Tec BP70002) to large, and my center(CLR2300) to small(I switched it back to large), and my rears(BP1.2x) to small.
But of course I will keep on playing with it!
P.S. Love your last sentence haha
post #76 of 1960
Warhawk and its THX uncompressed sound...truly amazing.
If you really want to get some sound, change your speakers to large, increase the bass side of the EQ and set your sub to PLUS. This will send all your bass to the sub and to the mains. The first time I fired the SAM launcher with my volume up I almost crapped my pants. Then when some guy blew it up while I was in it, I did crap my pants.
post #77 of 1960
I noticed that most people set their speakers to small and have their sub take all the bass. This has always made me think, why? If you have good quality front tower speaker, why would you want your sub to take all the bass? You should get tighter bass from a good tower and send all your LFE to your sub. I have an older set of NHT towers and center and set them to large and set my Velodyne sub to plus. I get fantastic LFE from this, yet don't get over-pushed bass from my towers when needed. When I tried them on small, I had to adjust the volume several times on my sub, because the bass sounded 'muddy' at times. If you have a HTIB or bookshelfs for fronts, then small is definetly the way to go. Anyone else use small for your fronts, even if you have a high-end set of towers? I am curious why?
post #78 of 1960
I don't have a sub and when I auditioned the BP7002 and BP2x(I have the 1.2x though) with the 92TXH, it was amazing watching Irobot with the car scene and all of the robots attack him.
post #79 of 1960
Ok..
I don't have a sub yet, but have a pretty decent fronts. How do I set up my speakers in that regard?
post #80 of 1960
One problem is that when set to small the EQ doesnt even show the 65hz range anymore. The next available setting is 125hz. The mains dont get much bass anymore in this setting. I like as much sound coming from my mains as possible so I set mine to Large. I double checked with my manufacturer and they concurred that they should be a Large
Ok..
If you dont have a sub then just set the speakers to large. Also go and have a look at your EQ to make sure the MCACC hasn't taken all the bass away.
I know many of the experts say that if you have a sub just set the mains to small but in my smaller room it makes the sub way too noticeable. I am experimenting with setting my fronts to large then lowering the bass at the 65 hz point for the fronts and center since most is done by the sub. I find this blends the speakers better with the sub.
Each room is totally different and mine is a nightmare to setup.
If you are serious about setting things up, spend some cash on a sound meter and a setup DVD like Avia. That being said if you use MCACC and it sounds good, thats all that matters.
post #81 of 1960
How do i know if the MCACC has not taken all the bass away? I am noob in this regard, so excuse my ignorance..
As for MCACC, I am not totally happy with it, and I had it disabled and used PCM Direct so far.
post #82 of 1960
Press Setup
Go into Manual MCACC
EQ Adjust
Start
Bass is on the left side of the EQ
I would suggest starting with MCACC since it will help you with speaker distances and levels.
Also once you have run MCACC you can look through Setup to check all your levels.
PS. Here's mine:
post #83 of 1960
Press Setup
EQ Adjust
Start
PS. Here's mine:
SIR! What we'd all like to see here is the Elite with its lights on. Thank you.
post #84 of 1960
Left side of the EQ? So, do I increase the bar? It's currently at -3 db on mine. thanks for your help on this.
Regards.
Press Setup
EQ Adjust
Start
PS. Here's mine:
post #85 of 1960
I would move around the 65hz and the 125hz to get more bass. If your 65 is at -3 then move it up a couple points until you get the bass you like. The 125 is a bit higher end bass but still good to enhance a bit.
as you wish:
post #86 of 1960
Cool. Thanks.
I will give it a try. BTW. You got the exactly same looking compartment for the receiver and PS3.. :-)
I bought it from iKea :-)
post #87 of 1960
mel22b, thanks for the pics. She sure is purdy . I'm waiting on my 94 to arrive. Can't wait to see TrueHD and DTS MSTR light up .
Nice apt. setup also!
post #88 of 1960
Thanks for the pics. There is no Pioneer dealer anywhere near my place for me to try it out. Are the knobs plastic or metal? I saw the 9120x (91TXH) at Best Buy and the knobs are plastic.
Oh, and it's probably been covered already but I'm too tired to go through all the posts.
Can the 92 or 94 apply THX Cinema processing on PCM for Blu-ray out of the PS3?
post #89 of 1960
I think the knobs are plastic.
Yes the 92 & 94 will apply post processing (THX Cinema included) to PCM from the PS3.
I confirmed this before I ordered my 94.
post #90 of 1960
Is everyone happy with the video side of the reciever so far? This has jumped to the top of my list and I want to be sure i will be happy when sending signals to my 1080p projector. Seems every reciever I looked at has some type of video complaint (artifacts / sync issues, etc).
