Originally Posted by
curlyjive
Do you have other HDMI sources that work fine? Such as a HD DVD or BD player? Movies have previews that may change from 1080i to 1080p and also switch sound formats. If you have one of those and it doesn't lose the signal than I suspect a handshake issue with the HR20. DO you have this issue going direct HDMI to the TV? I plan on using component with my HR20 b/c I have had issues with Directv's HDMI connections.
I don't have any other HDMI sources to test(been waiting for this BluRay HD-DVD fiasco to settle out or just go with an new OPPO).. I haven't tried a direct connection to the TV--good idea, but I couldn't leave it like that and have the 2808 as the switcher.
I am assuming if I have the STB(HR20) set to either 1080i or 720p output resolution, that would be a set resolution. How does the Denon need to be set to just pass this through?
Another thought, I have the HR20 menu set to 480i,480p, 720p, 1080i. I did this because I wanted my analog out to be active for recording to DVD and maybe this is what causing the changes/video sync dropouts during broadcast.
