There's likely over a dozen active Denon model threads going back almost 4 years. Sounds like amp failure if you have no speakers connected and it still shuts down. The microprocessor reset procedure should be listed in the table of contents of your Owner's manual ... near the back of the manual which is always worth doing before throwing in the towel. You might also want to pop the top and see if there are any blown fuses you can replace. If the decision is to replace it, your best bet on a limited budget, if you have Best Buy stores nearby, is to try to grab one of last year's lower level XX11/X91 models that have been on clearance now for a few months which should be within your budget.
