AVS › AVS Forum › HDTV › HDTV Recorders › Dish ViP722 DVR Best HD DVR on the market!
Dish ViP722 DVR Best HD DVR on the market! - Page 4
post #91 of 650
Hello,
I have a question that no one can give me a straight answer to.
I just signed up for TurboHD, and upgraded to the 722 in order to get a 2-tuner DVR. However, I was told that in order to use both tuners, I'd have to have the DVR hooked up to two TV's. I asked if I could record something on TV1 and play it back on TV2. First I was told yes, then I was told no. Based on what I've read here, I don't believe anything Dish has told me. But still, I want to be clear.
Quite simply, what I want is to be able to record one program while watching another, or record two programs simultaneously, all on one TV. Is this possible with the 722? Thanks.
post #92 of 650
You can do what you want to do. The DVR should be in Single Mode and you use the swap button to get to the other tuner for viewing. You can record two things, or three if you have OTA hooked up, and watch a prerecorded program, all a the same time.
Originally Posted by mumbles3k View Post
Hello,
post #93 of 650
Thanks, Bobby. That's what I thought.
post #94 of 650
How can i transfer data from 722? I would like to burn a dvd of some recordings, can i do that?
post #95 of 650
Ive got a similar question. Im getting a new 722 to replace my old one with a fried modem. Can I transfer my old recordings to the new one? Customer service said I could not. I read this whole thread and didnt find a detailed enough answer. Thanks.
post #96 of 650
The easiest way to do this is to purchase a USB hard drive, sign up for the external hard drive support, archive your recordings to the USB hard drive, and then transfer them to the new 722 when you get it. It is expensive, but it will work.
Ted
post #97 of 650
I do exactly that. I have the s-video output of the 622 (identical to the 722 except smaller hard drive) connected to my Phillips DVD burner I got at Wal Mart. It burns near commercial quality widescreen DVDs from HD programming. Unfortunately the DVD burner has no 5.1 in so I burn stereo only.
Just play the program you want to record, select the s-video in on the DVD burner, and hit the record button on the DVD burner.
Rick R
post #98 of 650
Hey guys, I have a quick 722 question. Mainly just about the wiring. I have the regular HD, non DVR receiver now for my main TV, and another SD, non DVR receiver for a TV in another room (non HDTV).
I was thinking of switching to get DVR capability on my main TV, and thought it would be nice to be able to run the SD TV off of this as well, but I don't think I understand the wiring.
Do you literally have to have a wire going from the Remote SD TV to the receiver near the main HD TV?
My house is wired well, but it's all to one main panel, not from the SD remote TV, to the HD main TV.
I don't really care about having recording ability, or even watching recorded TV from the second TV. Only thing I want the second TV to be able to do is watch regular TV and that's it.
post #99 of 650
Part of the upgrade fee that I paid included Dishnetwork coming out and installing a new dish and receiver. I did not even touch it until it was running.
post #100 of 650
Well, I already have the two HD dishes and two receivers, I just don't quite understand how the second TV gets the signal from the DVR.
post #101 of 650
Seriously? That little bit of coax coming into your second TV carries a signal.
post #102 of 650
If it is all wired to one panel, you can diplex the signal to TV2 over the same cable used to bring the satellite feed to the DVR. This is what I did. Works fine.
Ted
post #103 of 650
Really?
Ted
Thank you Ted. So basically the signal just simply gets sent all the way back through.
post #104 of 650
Really?
Yes. You just need a set of diplexers.
Ted
post #105 of 650
So here's my question: I'm looking at signing up for Dish soon (TWC can go straight to hell for all I care), and have this set up:
Main HDTV, second room HDTV, third room SDTV
If I get the 722, the sales rep said it would also control the SDTV via the dual tuner. So I would basically have the 722 in room 1, a 211 in room 2, and room 3 would be connected to the 722 as well.
Is there any disadvantage/advantage to going this way as opposed to just getting a stand alone receiver for room 3?
I do want the multi-channel recording feature of the 722 and if slaving it to a second TV would hinder this, I do not want to go this route.
Also, the 722 is capable of recording 3 programs and watching a fourth. Earlier in this thread, someone mentioned the third recording would be OTA-only. Is this the case, or can one record three channels simultaneously off Dish directly (SD or HD)?
post #106 of 650
The main disadvantage of using the 722 to serve 2 TVs is you cannot switch back and forth between the 2 live buffers. One buffer is dedicated to each TV. I have a 722 and a 622. I use the 722 in single mode and like to switch back and forth between tuners when watching 2 football games at once. I cannot do this on my 622 as I use it in dual mode.
With a 722 in dual mode, you can record 3 channels (2 SAT, 1 OTA) and watch 2 recorded shows at once (1 on each TV). You cannot record 3 channels off the satellite at once.
Hope this helps.
Ted
post #107 of 650
Ted, that is the way I'm setup -722 with the TV2 SD output sent back up the pipe to the main box which distributes throughout the house. Is there a way to take the TV1 HD output from the 722 and send it back up the pipe to other TVs (in addition to TV1)?
TIA
post #108 of 650
TIA
Not that I am aware of, but there may be whole house distribution systems that would work for you. I am unfamiliar with these other than knowing they exist.
Ted
post #109 of 650
This is the setup I have also. The advantage is that the SDTV can watch any show that has been recorded on the DVR. It also saves the $5 monthly fee for the extra satellite box.
The 722 can record three programs while the 2 TVs can watch two separate previously recorded show. I have done this. However of the three programs being recorded 2 are satellite and one is OTA. (two satellite tuners and one OTA tuner.)
As a matter of fact I have my 622 set to record three events tonight (Heros, Sara Conner Chronicles, and Dancing with the Stars) I will have to go into the bedroom to watch Monday Night Football on the 211.
Rick R
post #110 of 650
Thanks for the help! Install on 10/1. Can't wait!
post #111 of 650
The main disadvantage of using the 722 to serve 2 TVs is you cannot switch back and forth between the 2 live buffers...I use the 722 in single mode and like to switch back and forth between tuners when watching 2 football games at once.
I am unfamiliar as to how the two live buffer feature works. I'm a long time, unhappy, TWC customer and am used to losing any sort of buffer once I change the channel. It will only buffer what I'm watching even though it does have a second tuner. Once I move to another station, it's gone.
In what you're describing (in single mode) it's possible to switch between two programs you are not currently recording and the 722 will buffer both programs? So I could be watching program A, hit pause (without recording) and then jump to program B, pause and repeat? Or will program A automatically pause once I change to program B? Provided I don't change to a third channel, will program A resume from where I switched channels at that point (foregoing any pause/play button presses)?
This is quite the feature if true and miles ahead of what I'm used to.
Going back to single/dual mode. Is this easy to turn on/off? The standard def TV using the 722 is infrequently used, so it's not too big of a deal to me if it doesn't have a signal going to it all the time. If I turn it to single mode, does this completely switch off any programming on the SD TV? Or does this TV still maintain tuning functions, just without any DVR/buffering capabilities?
post #112 of 650
I have the 622, and will probably update to the 722 if they will do it for a reasonable amount.
I have the original Archos Dish Player and we love it, works great, plus I have a seagate 500mb external drive hooked up.
All in all I like the way they have implemented the storage management.
rg
post #113 of 650
evilmonkeys,
The 722/622 saves what you are watching for one hour. Thus you can back up, up to one hour. However, when you switch channels it throws it away. Thus you can back up up to one hour or to the last time you switched channels, whichever is less.
I have my 622 set to dual mode and the default timmer set to TV2. This means that when I set a timmer it uses TV2's timmer unless it is already set to record something else at that same time. The second TV can always be used normally except when this TV2 timmer is recording then it cqn only watch what is recording or some previously recorded show.
Rick R
post #114 of 650
my 722 modem went out 2 weeks ago and they sent me a refurbished one to replace it. okay, ill play that game , i said. i hooked it up and within a couple hours it would turn itself off. then again a couple hours later. in the morning it would require a pull the plug reset and then id have to wait to reconfigure sat signals and whatnot. monday morning i come home and do a pull the plug reset and i get the Terminator red eye of death. a red light came on for a second, then dimmed its way out. the unit is officially dead. so no tv monday until now. a new one should be here wednesday. it's quiet in the house with no tv. I requested them to send me a new unit, not a refurb. they said he would document the request but theres no guarantee id get one. well see tomorrow. if it is a refurb and it breaks again, im joining directv.
MJ out
post #115 of 650
MJ out
Good luck with that. If your DirecTV DVR breaks, they will send you a refurb as well.
Ted
post #116 of 650
OK, as the handle implies I work in satcom biz (engineering large commercial ground sations). Still, the whole issue of Direct to Home satellite TV (and cable for that matter) seems incredibly complex. Gosh, I remember all we had growing up in the SF Bay Area was 6 channels of B&W VHF analog OTA (susceptible to multipath "picket fencing" from P-3 aircraft on approach to Moffet field). Now ... . Pity poor grandma trying to figure this all out. I digress.
I saw an earlier post related to the matter of program archive that indicated that the only way one could keep a program was to remain a D* subscriber. The program would be stored on the DVR or an external drive. When D* subscription terminates, the program disappears into the ether, never to be seen again.
However, I wonder if this would work for permanent, non-D* archival: According to the manual it appears that you could use the remote TV (TV2) coaxial cable output as an input to a DVD Recorder (see page 109 of the manual). Is it possible to then use the DVD Recorder output (component or YPbPr) as an another Nearby TV (TV1) input. Could you record the arriving signal on the coaxial cable input (from the VIP722HD) on a DVD for later playback (using another TV1 video/audio input)?
Clearly it would not be HD, but if there was some program you wanted to keep, it seems like this would work. I have a Sony RDR-VX515 and would like to use it from time to time for permanent storage if there is a way.
Also, could I send a previously made DVR recording to the recorder through the TV2 ouput and record it? If that was possible, what if the original program was HD, would it work since TV2 is SD only (i.e. will the VIP722 convert HD to SD before shipping it out over the TV2 output)?
If TV2 SD output is digital, would this even work? I do not know if the Sony could record and play back an SD signal (it may be limited to analog). However, perhaps there are other DVD recorders that can. Or, could the SD signal be converted to analog before insertion into the recorder.
I'm sooooo confused. Thanks in advance for any comments or suggestions.
post #117 of 650
Quite an informative thread here. I am about to order new DISH service. I live alone and have one HD and 3 SD TVs. I am happy to use all 3 SD TVs as TV2. My research on the site leads me to believe that splitting the "agile modulator backfeed" to 3 TVs is no big deal. I have wiring in place and readily accessible for this. Does DISH care how many TVs I have connected as TV2? I assume I only pay based on the number of SAT receivers I have, as opposed to how many TVs I have hooked up to them.
post #118 of 650
Nope. split TV2 as much as you like. Mine goes 8 ways.
post #119 of 650
First of all, you guys are great at this forum.
I think I have a unique question/problem with my VIP722 and was hoping one of you would know what to do.
I have Dish Network with VIP722 receiver and love it, but Dish Network does not yet have my local channels in HD. So, I kept my basic cable subscription for $10/month because it includes my local channels in HD. I wanted record these HD locals with the VIP722 so I connected the cable line to the VIP722 via the antenna/CATV input on the back of the VIP722. I had the VIP722 scan for the local channels and it found nothing! (While scanning for locals, the VIP722 only scanned to channel 68.) The standard definition local channels are cable channels 6, 12, 24, and 51. The same channels in high definition are located at 102.1, 102.2, 104.1, and 103.7 on the cable line. Why didn't the VIP722 at least find the cable channels up to channel 68? Can the VIP722 even recognize the cable format? Is there any way to get those HD Locals into the VIP722?
post #120 of 650
Your local cable company most likely uses a technology called QAM to broadcast the HD channels across the cable. The 722 cannot tune QAM. The antenna input is for OTA (over the air) digital broadcasts only. You could get an antenna to receive the OTA signals, and that would work fine with the 722.
Ted
  Back to Forum: HDTV Recorders
