AVS › AVS Forum › Video Components › Home Theater Computers › HTPC - Linux Chat › Transcode HDTV myth recordings
post #1 of 13
What do people use to transcode their HDTV myth recordings? I've been trying to use nuvexport. For some reason, whenever I transcode HDTV transport streams to divx or xvid I get good quality but bad audio sync. And when I try dvd format I get audio sync but horrible quality (blocky), no matter what settings I seem to use. Any advice or ideas? I've tried using ffmpeg, mencoder, and transcode with nuvexport and have these same issues. I want to transcode them for playing on another device that doesn't support HDTV. So going down to DVD quality is what I really want, with a lower bit rate to save space.
post #2 of 13
MythTV hasn't save recordings as .nuv files for some time. They are now .mpg files
You can transcode recorded .mpg files from within Mythtv, using mythtranscode. I haven't this done for a while, but I found a How-To that looks to be correct
http://www.myhdbox.com/mythtips/2006...s-for-hdtv.php
The resulting file is a .nuv file. This will play on VLC in Windows. When I need a divx file, I transcode on a windows PC with the free DrDivX application.
post #3 of 13
Despite its name, nuvexport isn't just for transcoding nuv files. Not all myth recordings are saved as mpg (When I use a non hardware analog tuner card I get a .nuv file - but those aren't the files I'm interested in transcoding). As you stated when you transcode from within myth it actually does use the .nuv container, which is why I don't use it because it won't work in the device I want to use the recordings with, and it doesn't allow me to specify where I want the resulting file to go. I wish it did. The reason it uses a .nuv container is for audio syncing.
Does anybody else use nuvexport? I like it because of it's interface with the mythrecordings. If not, perhaps some commandline switches for transcode, ffmpeg, or mencoder that will work well would be appreciated.
post #4 of 13
I'd like to revisit this topic. I am also interested in trancoding HDTV captures after commercial flagging has been performed. I want to convert the files to a DVD mpeg file for burning to share with friends.
TIA
post #5 of 13
TIA
Mytharchive plugin --> http://www.mythtv.org/wiki/index.php/MythArchive
post #6 of 13
This does work but does not pickup the commercial flagging.
post #7 of 13
Hmmm...
Can use mythtranscode to cut out commercials from MPEG-2 recordings.
http://www.mythtv.org/wiki/index.php...of_MythArchive
I haven't really tried this...maybe someone else can help.
post #8 of 13
I use VirtualDub on the raw mpg and just mark the commercials myself (I find that the commflagging is not 100% enough to let it autoskip those parts).
post #9 of 13
Hmmm...http://www.mythtv.org/wiki/index.php...of_MythArchive
OK, I tried this, and I have successfully removed the commercials too.
First, you want to make sure that the commercial breaks are properly marked. Play the recording in MythTV, as you normally would. When the recording starts, press the E key, to bring up the edit mode. Here you can review the commercial breaks, and even add new ones. When done, press the E key again to exit.
More detailed info on this can be found here:
http://www.mythtv.org/wiki/index.php/Creating_a_cutlist
Now that the commercials have been properly marked, you can create a cut list. This is done using the terminal command, mythcommflag and the --gencutlist option.There are two methods, one uses the channel ID and start time, whatever those are. The other is to specify the path/name of the file. I used the path/file name method. My recordings are in the /video/TV folder, so my command for last Mondays "How I Met Your Mother" episode, looked like this.
Code:
mythcommflag -f /video/TV/1581_20081215193000.mpg --gencutlist
More detailed info on mythcommflag can be found here:
http://www.mythtv.org/wiki/index.php/Mythcommflag
Now start this:
Optical Disks-->Archive Files-->Export Video Files-->Create DVD
Select the options that you want. I selected "Make ISO Image".When I selected "Burn to DVD", it failed. Although the files were there, and I manually burned them to a DVD. (I was using a DVD+RW, and now I see that I had the wrong media selected) On the next page, choose "Add Recording" to select the recordings to use. When you choose a recording that has a cut list, the option to use it will then be available. Make sure that you then select that option.
Go through the rest of the pages and make the DVD as you want it.
Before doing any of this, you should set up Mytharchive. You need to have a folder with space for the DVD. Set that and the video format (NTSC) here:
Utilities/Setup-->Setup-->Media Settings-->Archive Files Settings
post #10 of 13
waterhead,
Thanks for the info. I will give this a try sometime.
post #11 of 13
Great info, waterhead. Thanks!
post #12 of 13
I also had an audio sync problem when transcoding recorded HDTV shows using Nuvexport in Mythbuntu 8.04. While investigating this problem, I did a lot of experimenting with Nuvexport and FFMpeg.
Nuvexport on my system was set to transcode all recorded TV (HD and SD) to MP4 files using ffmpeg. I found that ffmpeg had a problem with transcoding HDTV shows with Dolby Digital 5.1 encoded audio which would cause a severe audio sync problem during playback. Dolby Digital 2.0 HDTV shows transcoded fine. (I hope this isn't backwards, I no longer have the system to confirm). I downloaded bleeding edge SVNs of ffmpeg and couldn't find a solution, but I didn't go as far to submit a bug report.
Another piece of information - I also remember that I didn't start having this problem until I switched from a PCI Air2PC tuner to a HDHomerun tuner. I can only guess that the HDHomerun may be recording more than one audio stream that ffmpeg couldn't deal with. I think the Air2PC had a MythTv config option to only record one audio stream.
You can verify my finding by transcoding your recorded HDTV shows manually using FFMpeg. I suggest you record 1 minute of each type of audio encoded tv show (Dolby 5.1 & 2.0) to make the transcoding go faster. You can verify the type of audio in the recorded .mpg using the following command:
ffmpeg -i your_recording_file.mpg
You can transcode to MP4 using a ffmpeg command line something like this:
ffmpeg -i your_recording_file.mpg -vcodec mpeg4 -s 640x480 -b 1500k -acodec aac -ar 48000 -ab 128k -f mp4 test.mp4
I always transcoded to MP4 formats because I could also load it on my ipod
Tim
post #13 of 13
I've been searching for a way to simply transcode my ATSC transport streams to Bluray.
So far I've confirmed three things:
- that the mythnuv2mkv.sh script doesn't work as a user job nor on the command-line;
- that Myth's Transcode mpeg4 function uses ffmpeg to convert to DiVX 1920x1088 10bpp 29.970 fps, audio mp3 48000 Hz, 2 ch, s16le, 128.0 kbit/8.33% (ratio: 16000->192000);
- that ffmpeg can indeed convert to H.264 using libx264, but how to force this into Myth is a mystery.
I have not been able to confirm what audio formats to convert to in order to preserve 5.1 & 7.1 Bluray-compatible, nor what bitrate I should use for a quality recording. I guess just transcoding all formats present would be fine.
And Bluray 24f/s does not seem like it could possibly play without flicker.
  Back to Forum: HTPC - Linux Chat
