Originally Posted by drewex
HI recently setup my HT-AS720 to do 7.1 so i got my speakers setup perfectly went trough the test speaker stuff to adjust the volumes level. They all work. Now when i connect my ps3 over a hdmi cable i see the HT-AS720 show 7.1 setting is enabled it shows all the speakers on the screen. But i dont get any sound from the speakers at all. I researched the ps3 that the game i have is Call of duty 4 and it does give 7.1 output. But i just cant get this to work. There is no sound on the back speakers. Nor i can get sound from them in movies. Ok i get the movies because they are set to 5.1 right now but why doesnt it work with the games. What am i doing wrong.
Ohhhhh yes yes yes...... I just spent a an hour or so tinkering witht the 720's HDMI cables and comparing the optical connection.
My Results ?
When i run Straight HDMI with my reciever and PS3, here's what happens...
-I can't get DTS to Decode or DTS HD
-I can't get 7.1 MULTI-CH or LPCM Digital to turn off
-Dolby Digital 5.1 or Uncompressed 5.1 PCM to decode, Decodes as pro-logic 2.
Now, in the PS3 options you can select and de-select different sound formats in the audio option, and i've only had limited sucsess.
Going back to the optical connection for the PS3 seems to have solved all my issues, DTS decodes fine, with my Extra Speakers, DTS-ES 6.1 decodes fine, and Dolby digital decodes fine.
I should mention the TV HD reciever had no problems spitting out a nice DD 5.1 signal... so i can now say that however nice the HDMI switching is for the different peices of equipment, going old school for the audio "optical" for the ps3 gives you the less amount of pain.
All of this went down and hour ago. All of my modes are assighned correctly bla bla...
Does anyone have anything to add about the different sound formats with the PS3 and this AMP ?
then from there into the second HDMI input on the HT-AS720. The PS3 and Xbox will never be turned on at the same time. Will that type of HDMI "Y" connector work? I dont really see why it wouldnt.
