AVS › AVS Forum › Audio › Home Theater In A Box › Official Samsung HT-AS720 thread w. updated first post.
Official Samsung HT-AS720 thread w. updated first post. - Page 8
post #211 of 1646
Originally Posted by bdrex28 View Post
do you still have the samsung? And if so, can you do the calibration and let us know your results?
thanks
I'd love to, but I don't have a sound meter so I don't really have a way to calibrate it. The Onkyo's auto calibration is pretty slick.
post #212 of 1646
so i have a samsung tv that I have all my components plugged into. Can i just run the optical out of the tv and get 5.1 sound etc from all my sources plugged into the tv?
PS3, DIRECT TV hd-DVR ETC?
post #213 of 1646
Nope. The TV only outputs 2-channel audio though its optical out if you're using an HDMI input.
post #214 of 1646
so now the question i have for everyone is
on a scale from 1-10 how would you rate the AS720
and
who has stands for the speakers?
post #215 of 1646
I'd like to know as well from members who have got it already. I'm in the middle of going in the US and buying it soon ( as Samsung CS Canada didn't even reply to my email for Canadian availability ) and I'd like to see if it gets thumbs up or down ?
post #216 of 1646
and
I give it a 10.. thumbs up, its been working awesome and the sound is great, the sub is powerful, more than I expected.
The stands that you can see on my posted pics are from Ikea, and are really nice.
post #217 of 1646
You may have posted this already, but how big is the room you are in?
post #218 of 1646
im in a 14x12 room. sound fills the room at 60 percent volume usually cant go higher or it will shake the walls.
my judging is based on HTIB's ONLY.
sound 8.5
(fills a small living room and big bedroom well might need something more powerful for a LARGE living room like (SR800 or better)
looks 10
(by far the sexiest HTIB on the planet)
connectivity 7.5
(could use components and S video and have some upscaling as well) only 2 HDMI .. 3 would be ideal (like the ss2000). does have HDMI all in 1 (unlike the SR800)
user friendly 8
(fairly easy to use [esp with anynet+] toggling the buttons on the remote is basically all you need to do)
future ready 9
(with all the decoding options as well as the passthrough as well as 7.1 exp)
price value 8.5
(not overwhelming and not cheap 509.99 is decent for what you get and dont expect a 3000 dollar system to come from something that is only 500. does its job for well worth the money)
post #219 of 1646
whats the model # on those i cant find them on the website.
post #220 of 1646
I've been waiting for this to come out, but I'm a little concerned by some of the things I've read here...
I have a Samsung 46" LCD TV, A Samsung standard DVD + VCR Combo recorder, and a SA8300 cable box. Now, I know all this will work fine (HDMI outputs from the SA8300 and the DVD player to the AS720, and then HDMI to the TV). But what happens when I add an XBox360 to this? How will this work? Will I have to switch to component video for the SA8300 so I can use the HDMI for the XBox? And then the cable's audio and video won't be in sync (i.e. I'll have to select the inputs separately?)
I have a Harmony remote so maybe this won't be a huge issue.
For the record, for anyone looking at the +AnyNet functionality: If you have a Harmony remore, you have to turn this feature off or it confuses the hell out of the remote. So that's all a non-starter, and is all completely irrelevant, if you use a Harmony remote, or any other "universal" remote that keeps track of all the components of your system for you.
Final question: I'd like the option of watching as I do now (just standard TV speakers) as well as going with the full surround sound. I don't always need or want the full loud rich sound experience (especially if I have company and they want to watch TV while I'm sleeping, or vice-versa). Is that all possible?
Thanks for any additional info...
post #221 of 1646
well you have several options .. if your xbox 360 has HDMI and your cable box does too those would be your 2 in's .. you might want to do component on the DVD player and or the cable box since no DVD is in 1080p and no cable program is higher than 1080i. i think direct tv is the only one that broadcasts 1080i anyways, not too sure you might want to check. id go with the cable box and xbox with the hdmi and hook everything else up optical/coax OR you could buy an HDMI splitter but that will be 100 bux
post #222 of 1646
Couldn't find them either, I'll check the bottom of them today, they have the name on a tag. Anyways they might have been discontinued, like I said, I got them for 9.99 a pair. Go to the store, you might find them there they don't always post all on the website.
I'm on a 18' x 20' living room, and if I go over 35 on the volume it will shake the walls.
post #223 of 1646
does anyone have a sammy 4095d with anynet??? I cant find it anywhere so I'm guessing it doesnt have it... Or I'm just not looking in the right place... I'll love to try this anynet with this system...
post #224 of 1646
The stands are Model : GAJE 17778, thats all the info I have.
post #225 of 1646
It's been asked a few times, but hasn't been answered yet:
Could anyone take the time to measure the dimensions of the Receiver? (only the speaker dimensions have been given so far)
post #226 of 1646
found them also. i called ikea. avail in store ONLY. not discont, just in cataloge
post #227 of 1646
After reading through the PDF instruction manual provided earlier, I can answer my own question.
Receiver Dimensions: 16.9w x 5.7h x 13.7d
post #228 of 1646
I'm interested in the AS720 but I was wondering if the avr had trouble converting video sources from DVI to HDMI? I'm also wondering if I can hook up my htpc with a digital coxial out to the av receiver and still get surround sound?
post #229 of 1646
For me, the Onkyo SR-800 will be a better system, I think. I'm running 2 x HDMI and 2 x Component. I have a PS3 (HDMI), a 360 w/HD-DVD (HDMI or Component), an HD FiOS internet (HDMI or Component), and a Wii (Component).
The fact that this system doesn't have component inputs/outputs is what will stop me from buying it.
EDIT: I guess I should also say that I'm probably almost never going to be using this to play CDs. It'll be at least 90% Blu Ray/HD-DVD movies, HD cable, or HD gaming.
Unless someone can show me that I'm really missing some key advantage of this system, I'm going to buy the Onkyo SR-800. Any thoughts, comments, and concerns are very appreciated!
~Paik
Any thoughts?
post #230 of 1646
the SR800 is actually a good system except it doesn't have true hdmi pass through. You still need an separate audio cable source and it doesn't support hdmi 1.3a. So if you're happy with supplying your own audio sources for hdmi then by all means go for it
post #231 of 1646
Hrm...so that means for both my HDMI connections, I'd have to run a digital optical cable into the receiver? That wouldn't be a big deal for me at all since it has two digital optical inputs anyway. I guess I'm going to get it then! Thanks!
~Paik
post #232 of 1646
I thought the SR800 support HDMI v1.3 HDMI pass through.
http://www.onkyousa.com/model.cfm?m=...&class=Systems
post #233 of 1646
screw that who wants to go buy a zillion optical on top of spending that kind of cash
post #234 of 1646
my bad it actually does do hdmi 1.3a :P but only as a video pass through.
post #235 of 1646
I'd rather have two more digital optical wires than not having any component inputs. Aside from the HDMI audio pass through of the Samsung system, I see the Onkyo as a better system.
~Paik
post #236 of 1646
yes i do. they are ALL supposed to work in conjunction. yes, if i turn my blu ray off the tv also turns off. you can program it however you like, AND to top it off one remote does it all, volume, inputs, and all.
I do all this with a universal remote that cost me under $100... factor that in, and paying the $$ for a HTIB without component inputs might not be so cost effective...
post #237 of 1646
~Paik
I've been very impressed with the Onkyo 605, which does pass video and audio over HDMI (as well as upconvert analog sources to 720p so they can be sent to the TV via HDMI). If you're going to go with an Onkyo, you might want to look at getting the 605 and a separate speaker package. It will cost you a little more (depending on which speakers you get), but I think you'll get more bang for your buck.
post #238 of 1646
Right now, Shoponkyo.com sells Onkyo SR-800 (refux) for $349 + tax + free shipping = $369
New Onkyo SR-800 at Vanns.com for $415 + no tax (CA) + no shipping or accessories4less for 329$ + no tax(CA) + ground shipping ($75)
Or you can get New Samsung HT-AS720 at Bestbuy.com and use 10% off coupon.
post #239 of 1646
Thanks kasuza! I'm going to buy the system now!
~Paik
post #240 of 1646
the AS is 509.99 still at BB. they refuse to use that coupon, unless you get a dumb one.
  Back to Forum: Home Theater In A Box
