Originally Posted by joed32
They know about it, whether they know how to fix it is the question. Lots of talk around the web about this topic. They are saying that if you do a red button reset and then do another one as soon as the program comes back on it will flush your guide. Then after about 24 hours when it has been rebuilt the problem is gone and Search works the way it should for about 3 weeks. Then you need to do it again.
It can't hurt to call and complain. We should all complain. If they keep getting complaints, they'll be more likely to fix it to stop the support calls.
Red Button resets for a long term search for things I hope might eventually appear (I have a couple series not available through home video I'm set to record if a channel starts to air them at some point) is not a solution. I need the DVR to detect and pick up this stuff reliably.
They broke it, they need to fix it. It worked before.
