AVS › AVS Forum › HDTV › HDTV Programming › DirecTV HDTV
DirecTV HDTV - Page 426
post #12751 of 14319
I saw the biker show commercial and said "Discovery has really hit rock bottom"........then i saw the commercial for "World's scariest plane landings" and said Awesomesauce!! Another airplane show!
post #12752 of 14319
Originally Posted by foxeng View Post
Wasn't she just on a CSI:Miami a couple months back as a Mexican Police Chief the drug cartel was after?
Yes that was her. I was channel surfing and ended up catching the last half of it.
post #12753 of 14319
I now call Nat Geo channel the Weed channel.
post #12754 of 14319
So I just signed up for directv, and the installation guy just left. This will be the first time I've had a provider in 6 years. I went ahead and took advantage of their "big deal", and I like it so far. And I'm glad I'll finally be able to watch live Astros and Texans games.
Quick question though: When I watch premium channels in dolby digital, the center channel volume is super low compared to the surrounds/LFE. Does anyone else get this? Any fix other than adjusting levels on my audio reciever? The levels are perfect for bluray/htpc/xbox, I'd hate to have to adjust that level back and forth when switching sources.
post #12755 of 14319
MisterClean84,
Make sure your DTV receiver has Dolby Digital Audio turned ON:
Menu => Settings => Audio => Dolby Digital = ON
If that doesn't correct it, it's likely an issue with your AVR. Is your DTV receiver sending digital audio via HDMI, Optical or Coaxial to the AVR? Check your AVR settings for the appropriate digital audio input.
post #12756 of 14319
Originally Posted by gerhard911 View Post
MisterClean84,
DD is set to on, and it's going through HDMI to my Pioneer VSX-1121k. I've since changed channels (to stars HD from Cinemax HD) and the volume issue isn't nearly as noticeable. So it may have just been the particular movie I was watching, or possibly the channel. Appreciate the help, though.
post #12757 of 14319
It's mostly the show or channel. I have watched Whale Wars before where every single speaker had the same level and it was awful. The next episode would be back to normal.
post #12758 of 14319
I remember watching a Vikings nfl game years ago where John Madden only talked out of my left rear speaker. The lesson being:
Step 1: Try another channel.
Step 2: Panic, curse alot, report the problem on AVS forums.
post #12759 of 14319
All the blue lights are on my receiver...usually that means there was an update.
Anyone know what the update is?
post #12760 of 14319
MisterClean84,
Also under that same menu sequence , you have the choice for surround effects = Low- Medium- High . I like medium
post #12761 of 14319
Those are sound effects associated with screen navigation, nothing to do with "surround sound".
post #12762 of 14319
See http://www.dbstalk.com/showthread.php?t=204388
post #12763 of 14319
So out of curiosity which HD channels is DirecTV missing as of right now compared to Comcast? Well besides the worthless G4 that is.
post #12764 of 14319
It should be fairly accurate, there's been a lot of work on it lately.
Official AVS National HD Channel Lineups - Cable/DBS/Fiber/IPTV - Updated 3/25/12!
post #12765 of 14319
BBCHD is one that comes to mined
post #12766 of 14319
According to the list linked above, about 20 by my count (not including regional sports). That's pretty much the same margin they're behind other providers as well (U-verse, Dish, etc.).
post #12767 of 14319
Looks like after a short hiatus, local inserts are back. Just noticed it today. On CNN they went to break, started out as a TruGreen commercial then switched to a stretched Academy Sports spot. Went channel up and back and the TruGreen commercial was back.
post #12768 of 14319
These days, doing a channel up and than down again can sometimes take an entire commercial break! Okay, an exaggeration, but it feels like it.
post #12769 of 14319
Lovin' it!.....One time where "smell-o-vision" would come in handy!
Maybe this new FW will solve that...God I hope!!!
post #12770 of 14319
That's right forgot about that listing. Looking at it now looks like I would be missing very little by jumping to DirecTV from Comcast. BBC America HD I was looking forward to getting on Comcast until every time I looked at the network they were showing ST:TNG reruns.
Also looks like a few others like E! and Lifetime Movies is missing which is no real loss to me. I'll give those up for HDNet Movies, GolTV HD, and the like.
post #12771 of 14319
I have an HR21 hooked up in my basement. I had component going to my projector and hdmi going to the tv behind the projector. Recently, the tv would not receive signal from the D* DVR.
The hdmi on the tv does work, as I hooked up a blu ray to it to test the connection.
So either the hdmi jack on the box has failed, or the new update disabled it maybe?
Any ideas?
post #12772 of 14319
Any ideas?
My money is on the update disabled it as others are reporting the same type of issue for hdmi...
http://forums.directv.com/pe/action/...ostID=11054026
post #12773 of 14319
If the update disabled it, I can tell you that it disabled my (older) HD television. I purchased a powered HDMI splitter from MonoPrice. It is part MHSP0102B, and is advertised as supporting HDCP. It is a 1 to 2 splitter, but I am using only one of the outputs. It solved my problem, so if that's your problem, this will work for you. It beats unplugging the HDMI cable from your HR21, then plugging it back in again. It was pretty cheap, but I can't remember exactly how much.
post #12774 of 14319
Yeah, using an HDMI switch (splitter do the same?) as a generic problem solver for HDMI connections should be a sticky or something I use a 1:2 Monoprice (used as 1:1) switch between DTV receiver and DVDO Edge - tried it between Edge and display, but it works better, reduces problems maybe 80%, directly after the sat box.
post #12775 of 14319
I believe the update disabled by receiver on Saturday...but only temporarily.
It wouldn't turn-on. I unplugged it, re-plugged and everything is back to normal.
post #12776 of 14319
Thanks guys.
What about this one:
I do not want to have a powered one if I can help it due to lack of outlet space.
post #12777 of 14319
You want a powered one. Make the space.
post #12778 of 14319
Thanks guys.
The one you linked to is not HDCP compliant, it supports HDCP pass-thru, which means, since your problem is due to a handshake issue between your receiver and the display device, this won't change that. It will be useless. The powered one I mentioned here IS a bit more, at $33.50, but it clearly says it's HDCP compliant, and it is because it works (for me).
post #12779 of 14319
Thanks guys.
I will give it a shot!
post #12780 of 14319
Got the latest FW (HR-24) and I can't find anything wrong with it. Dare I say they got it right finally?
  Back to Forum: HDTV Programming
