Originally Posted by Steve S
Dumb question, and please excuse me for asking, but have you checked to see what resolution(s) your HD DirecTiVo is outputting? Up until a couple of weeks ago I was using an OTA HD TiVo that gave the best results when set to output only 1080i.
I switched from the OTA box to DirecTV's HR24-500 DVR, set the box to output only 1080i and 1080p. I was apprehensive about the pq for locals as the Dish HD locals where I work (I sell tvs) truly are unwatchable due to compression. I was pleasantly surprised to find the D locals were virtually indistinguishable from the OTA pq. Of course there are a lot fewer locals here in the Fresno market than in the SF/Bay area.
My DirecTiVo is set to pass the original signal format, and is connected via HDMI. I have personally tested and confirmed that 480i, 480p, 720p, 1080i, and 1080p24 are all functional and display properly. Therefore I do not believe that any scaling or reformatting of the signal is occurring in the DirecTiVo THR22.
If it was not obvious before, then follow this explanation of why the DirecTV locals are NOT THE SAME SIGNALS as the OTA versions. The OTA HD broadcast channel originates as an MPEG2 network feed but the local OTA broadcast is a multiplexed signal that includes the network HD channel and up to five 480i (digital modulation) subchannels. The channel bandwidth of the OTA signal, comprised of a multiplexed HD main channel plus up to five SD (480i digital) subchannels is 6Mhz. DirecTV is using MPEG4 modulation to save bandwidth, but they are also stripping the subchannel content before broadcast. So the total steps are as follows:
1) The Network HD feed is supplied in MPEG2 compressed form to the local affiliates. The signals are decompressed and multiplexed with one or more SD subchannels, plus music broadcasts, teletext, etc. content from the local station. The multiplexed signal is recompressed (again with MPEG2 lossy compression) and broadcast OTA.
2) DirecTV receives the OTA broadcast, decmopresses it, strips the SD subchannels and other local content, and recompresses the HD signal only with MPEG4 lossless compression for the DSS signal.
3) The DirecTiVo receiver decompresses the MPEG4 lossless signal as HDMI digital video.
THEORY SAYS that the OTA broadcast and the DirecTV signal should be the same quality, since both received two complete compression/decompression steps using lossy MPEG2 codexes, and the the DirecTV signal only received one additional compression/decompression step, using a lossless MPEG4 codex.
But I can see a difference, the DirecTV version of a local channel has compression artifacts including macroblocking, loss of contrast, and especially video noise in dark areas of the image.
This should not be happening, but it is. I blame DirecTV for the quality loss (it is their broadcast after all), but I don't know how it is happening.
MichaelLAX, I did check out the "Test Satellite Signal Strength" screen, and most of the transponders are in the 90% range with the lowest signal showing 82%. So I think the dish is aimed correctly and installed correctly.
