Hello, got my unit in the day before yesterday, I literally "stole" my local dealer's demo unit from him, hehehe. Poor guy never got to hang it up in his shop or open the box.
My VW60 is replacing my Runco CL-710 (720p DLP). I use a Vu-Tech Silver Star screen. I've forgotten the precise measurements since I got it four years ago, but I believe it's 90" wide on the horizontal and a 6 or 4 gain. The throw distance is about 12 feet. Right now I'm waiting for the tech to come hang it, and it's sitting on top of a table and two boxes right below my Runco.
I'm running in HDMI from a Denon 2930 outputting a 1080p upconverted signal. My Sammy 5000 will be in in about a week (drool), so no HD player yet. These calibrations were made using DVE, AVIA and (for Color/Hue only) the THX Optimizer. I've found it's much easier to use than the others and just as accurate. The only thing I miss from my Runco is the Blue overlay for calibrating Color and Tint. I hate standing there with the stupid little card to my face from DVE, but it's better than nothing I suppose.
Settings. I've spent several hours fiddling. Though I don't have any test equipment, I have several thousand hours clocked in watching a projector that was calibrated ruler flat, so I have a good idea what to look for, especially with my standard demo/calibration material.
I'm going to stir up the waters a bit with the second half of my calibration report...but on to the more conventional NTSC side, I have found I use the same calibrations whether the lamp is set to Low or High. Some may want to bring their Brightness up or down a notch or two depending on the lamp level, though.
I've found that Auto Iris 1 crushes whites. I noticed this in the Superbit edition of Spider-Man. Right after Peter beats up Flash in the school hallway, the camera turns to Harry and he says, "Peter that was fantastic" (paraphrasing here) and with the iris set to Auto 1, all the detail in his forehead is simply gone. He looks like an alien. Changing to any other iris mode alleviates this. I experimented with Auto 2 "recommend" (haven't tried fast or slow) and I could see the iris changing, and though it was a truer image than Auto 1 (which heavily pushes red and crushes white), I just don't like the look of it. It's not natural. What I found works VERY nicely is to use the manual iris setting (Iris Off I found by looking at the thing opens the iris to 100%) at 75%. This gives an extremely nice tight contrast without any defects of a moving lens.
Also, according to calibrating with both DVE and AVIA, a Max contrast works perfectly well. No crushing of whites beyond the three vertical dots in the contrast screen on DVE, no loss of the finer white bar in the contrast adjustment on AVIA.
CINEMA:
Lamp: High
Auto Iris: Manual @75%.
Color Space: Normal
Contrast: Max
Brightness: 48
Color: 50
Hue: 50
Color Temp: Warm
Sharpness: +5
Black Level Adjust: Off
Gamma Correction: Off
I fiddled a bit with RCP, but went back to turning it off in the end.
For Low lamp level I was ultimately able to use the same Brightness, though mileage may vary a +/-1 on this for others.
USER 1
Lamp: Low
Color Space: Normal
Contrast: Max
Brightness: 48
Color: 50
Hue: 50
Color Temp: Warm
Sharpness: +5
Now comes the controversial part. And before I say this, please understand I'm just as much of an obsessive-compulsive, anal-retentive, "I want to preserve the filmmaker's original intentions", geek as the next A/V freak. But I gotta tell ya, if you want you movies to look like real life--like you're looking out your window at the real world, the Wide Color Space is where it's at. At first this color space looks like carnival colors and you say, "Aaahhhh! Take it away! Give me back Flatland!", but all that needs to be done is to turn down the color saturation a bit and watch something with nice, natural daylight colors for a little while until your brain adjusts and you won't be able to go back to "normal". The truth is, NTSC is just a sucky standard from the 50's and is not realistic. Wide color gives redder, more natural flesh tones WITHOUT screwing up basic white, and this is what makes it very, very nice. And very natural. Give it a try with T2 Extreme Edition. Go to the scene where the kids are outside the ATM. That blue jean jacket actually looks like a blue jean jacket, now. The kid's red hair looks REAL (I know, I have red hair), it never did to me with "correct" color calibration. And the flesh tones are perfect. The key to using this mode for me was to decrease color saturation a bit until the exaggeration of the added color space is taken away. I did it by eye and came out with very good results. Anyway, here's my settings as that goes:
USER 2:
Lamp: Low
Color Space: Wide
Contrast: Max
Brightness: 48
Color: 47
Hue: 50
Color Temp: Warm
Sharpness: +5
USER 3:
Lamp: High
Color Space: Normal
Contrast: Max
Brightness: 48
Color: 47
Hue: 50
Color Temp: Warm
Sharpness: +5
Cheers,
Omar
