AVS › AVS Forum › Gaming & Content Streaming › Digital Recorders (PVRs) General › Direct TV R15 vs R10
post #1 of 4
I have a R10 series Tivo through Direct TV and it has been restarting itself at random times over the past month. I was hoping the problem would work itself out, but it hasn't.
I called Direct TV and they said they would send a replacement, which would be the Direct TV DVR Plus R15 model. I have read numerous negative reviews on this product so am a bit confused on what to do.
Have any other users made the switch to the R15 with positive things to say about it, or know of a current fix to my tivo dvr problem?
(this is a bit strange, but a friend of mine also has a Direct TV tivo and this same month is having the exact same problems I am having...)
post #2 of 4
Before getting an jumping on that R15. Check these thread on your issue, it seems it was caused by a software update.
http://www.tivocommunity.com/tivo-vb...d.php?t=364660
http://www.dbstalk.com/showthread.php?t=76110
Edit: added second url.
post #3 of 4
Pray you can get your Directivo fixed....I wish I had kept mine.
post #4 of 4
The R15 is the worst dvr i had ever use. I never had the chance to use TIVO but i have a ReplayTV, and GBPVR on a PC and they are far way better. if anyone have a better choice than a R15 take it.
