AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Info on Mitsui LCD TV's?
post #1 of 4
Hi Guys,
I live in Mexico, and recently took a look around the local Wal-mart and found a Mitsui 32" LCD TV decently priced, and it even had a DVI connection for computers, which I found strange since budget LCD TV's almost always lack this. I came home to see if I could find information on it, but I'm having a very difficult time trying to find ANYTHING on Mitsui TV's! I'm not sure if they just don't sell them in the States or what, but I would like to find some more info on it.
I may have to go back and try and find the model number on it, that would probably help, but if anyone has an idea it would be appreciated. I've done a little research and it seems that Mitsui does work with Nuvision, which seems like a promising LCD company, but their TV's do say Nuvision on the front, although they look pretty similar. This one said Mitsui.
I'm looking for a LCD TV that I could use as a monitor. Obviously I would like to find a decent one that is 1080p, but those are severely lacking here and usually EXTREMELY overpriced (The Sharp 32" 1080p is about $1600 US at Sam's Club ).
post #2 of 4
Are you referring to Mitsubishi displays?
Sorry... just noticed the i at the end of the name; I thought you had written Mitsu instead.
post #3 of 4
Nope, Mitsui, unless they are the same, but I'm pretty sure not. Here are some links to (what I think are) their websites, they do talk about LCD Displays and such, but don't have any actual products listed:
http://www.mitsui.co.jp/en/index.html
http://www.mitsui.com/index.shtml
http://www.mitsuicomtek.com/
I'm confused too
post #4 of 4
Nada?
