AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › Official AX-200 Owners Thread
Official AX-200 Owners Thread - Page 7
post #181 of 3079
Anybody using a HD-A2 player with this? The player does 720p/1080i so I'm thinking which would give me the better picture overall (??). Research tells me to stick to 720p on the player as thats the PJ native res but people say 1080i is better (??)
Cheers
Frag
PS: If I dont die tomorrow or the AX200 doesnt get out of stock in US, I'll be ordering one
post #182 of 3079
u might die tomorrow though
post #183 of 3079
Originally Posted by scotty144 View Post
Can any owners comment on the new dynamic sharpness feature.
the dynamic sharpness feature is supposed to enhance the sharpness around brighter areas of the picture. It creates a more natural look compared to some of the more uniformly sharp pj's that i've seen (especially epsons which look kind of harsh, and mitsubishi's which are sharp, but aren't harsh enough, i guess that sounds weird, but their picture seams weak to me). I gotta tell you though, i've had this thing a week, and you'll never notice any of this tech because you'll just be so damn pleased with the image. when people say this is a virtual 1080p projector, they mean it. no other 720p projector has received that compliment.
post #184 of 3079
Fragster I certainly hope you survive to enjoy this fine machine
post #185 of 3079
I got my answer directly from Panasonic in and email this evening.
Lamps are only warranted for 90 days or 500 Hours whichever comes first. The Projector Parts and Labor is covered for 1 year or 2000 hours, this “promotional” second year extends it an additional 2000 hours. So in total the unit is covered as follow
PT-AX200 (with promotion from Authorized Dealer / Reseller)
2 Years or 4000 Hours (Parts and Labor)
Lamp Warranted for 500 Hours or 90 Days
Keep in mind that this promotion will be for a period of time only and will eventually go away.
That's straight from Panny and I'm going to hold them to it. I am replying and asking where/how do I get these forms or promotion warranty. I'll ring back in when/if they reply.
post #186 of 3079
I sent you a PM. I would love to get a copy of that email for my records. This is the first time I've seen 4000 hours mentioned!
post #187 of 3079
Thanks for the info Mark. Hopefully you will get an hd source hooked up soon so you can comment on the sharpness issue. And any more head to head impressions are much appreciated.
post #188 of 3079
The AX200 is an absolutely fantastic PJ, for the money.
I've just finished revisiting 6 HD titles and I'm totally blown away at the quality of the image on my 110" (16x9) Perm-Wall Screen in my dedicated HT room. This is the 4th. PJ I've actually owned. I also once had a VW50 for a couple of weeks, I took it back because I thought it was kind of "soft" for the $$$.
If you're budget is $1200, you'd have a difficult time finding anything wrong with the new Pany AX200. Lots of guts for the bucks.
post #189 of 3079
Cheers
Frag
Most have found that the 1080i setting in the HD-1 0R 2 gives the best pic.I would like to see is the new hd-30 that does 1080p 24fps will do since the ax200 excepts 1080p 24fps/BOB
post #190 of 3079
I was feeding the AX-200 with the new HD-A30, first in the 1080P and then in the 1080p/24 mode.
post #191 of 3079
With my Sony 50 inch sxrd rptv I found that 720 looked somehow better over all. Seemed better in moving shots. I can't actually describe it...I will hopefully begin playing with this new panny Saturday and will hook up the A2...
post #192 of 3079
j-bo,
I think it would be beneficial to all AVS members if you posted the e-mail in this thread. I'm also sending you a PM with my e-mail addy as I'd love to have a copy of it in case I pull the trigger on an AX200. Thanks in advance.
post #193 of 3079
Here is a link to the extended warranty info for the Panny -
http://catalog2.panasonic.com/webapp...odel=PT-AX200U
post #194 of 3079
I think it's a shame that the rebate form, the post on Panny's site, and the email directly from Panny support contradict each other!
post #195 of 3079
Does anyone have a projector mount recommendation for the ax200u? I just ordered mine and realized that I donot know whichmount toget. Any suggestions for a good mount?
post #196 of 3079
Duct tape?
post #197 of 3079
Guys,
I am seriously considering this projector to replace my IF SP4805. I have a total dark room, 106" diag screen (Behr SS paint), and pj is ceiling mounted. Mostly I watch DVD , and plan to upgrade to HD-DVD/Bluray soon. I want this instead of a pricier 1080p PJ for the time being. Affordable at $1300 price point for me.
Since the 4805 was my only PJ, I feel I can improve in 2 main areas. Reduce Screendoor effect at my sitting distance, and also improve black levels.
1) I know the SDE is gone in this PJ, but wonder if the black levels would be an improvement over the 4805. Can anyone comment on that?
2) Can someone comment on whether I can expect same 3d-like image in this PJ compared to the 4805?
3) What 'issues' can I expect from LCD projectors, as I have never owned one. I know rainbow is not an issue, but are there other visual things inherent to LCD technology that I need to be aware of? Banding I hear of?
Thanks. I need some info before I purchase, and I really trust information from the more experienced folks here that have owned multiple pJs.
post #198 of 3079
Also, a question about Lens Shift:
Is it done digitally, or optically? If it is done digitally, I assume that when you shift the image to the right, you will have 'black' projected imagery on the left of the screen. Which in my experience is never trully black (rather, grey), and is distracting.
Can someone clarify this for me, as it would be a deal breaker.
post #199 of 3079
The AX200's lens shift is done optically. It is manipulated using a joystick on the front of the unit.
post #200 of 3079
Awesome. Is it done mechanically, or is there a micro servo that moves the lens? i.e., is it like manual side mirrors on cars, or like electrical mirrors?
post #201 of 3079
Manually. Quite easy to do.
post #202 of 3079
Please report back with impressions, since I also plan to upgrade from IF 4805.
Originally Posted by Rahl View Post
I put in my order today for one. I'm upgrading from a 4805 on a 120" screen to this. Can't wait!!
post #203 of 3079
post #204 of 3079
I am also a previous Infocus SP 4805 owner. Any PS3 owners out there that have this projector yet? Would like to hear your thoughts and impressions, and possibly pics. My trigger finger is itching badly.
post #205 of 3079
fire man fire without looking back
post #206 of 3079
I just pulled the trigger and purchased one today. Should be here next week. Can't wait!!!
post #207 of 3079
Now why don't they make this thing BLACK? Of all colors, white? Geez!
post #208 of 3079
looks good in white
post #209 of 3079
Most are white so thay blend in with the ceiling.
post #210 of 3079
Couldn't agree more...
A nice matt (not some awful piano shiny black) boring black would be great...
