Originally Posted by Madaeel
Thank you Tony. I personally love how it sounds. I had a Polk center channel before this Axiom and I think it's a little clearer because it's off the stand and elevated. Plus you're supposed to keep your speakers level as much as possible and it certainly is better this way. It just sounds better than the Polk in general as well. If you like the look I think you'll be more than happy with the sound. Right now I have it calibrated even with the other two fronts and dialogue isn't a problem. I think we all experience those "what did he say" moments but that's usually the way it was mixed and you have no choice but to turn it up. So far though I haven't had to. I'm sure Axiom recommended the 150 because it can handle more power and the dual tweeters probably help with those moments. Either way I think you'll be happy. Hope that helps.
Hi Madaeel,
Did you think about tilting the center channel slightly aiming the tweeter towards the listening area? I can't tell in the picture. Did you do that?
Thank you,
tony
