AVS › AVS Forum › HDTV › HDTV Programming › Mediacom HDTV
Mediacom HDTV - Page 6
post #151 of 815
Originally Posted by jeffer96 View Post
It was a pleasant surprise to turn on the TV last night and see the Cubs in HD. I had to do a double take to realize Mediacom added WGNHD 825 in Des Moines. Looks like KCWI HD is also there 809. Now if we could replace FoxSports Midwest with FoxSports North, I could watch the Twins and be a very happy man.
Sorry, I got my request in before yours, to have FSN MW on forever.
The WGN HD and KCWI additions are certainly nice (and surprising).
post #152 of 815
Originally Posted by slats View Post
I apologize if this is not the right place to ask this question. I read thru this thread and others in hopes of answering these questions...and only got a partial answers. So, I'm asking for a little help.
I'm in NW FL on Mediacom. Main TV is HD feed from a Pace box thru a Yamaha 663 to a Sony XBR. Bought a Vizio 20" for a guest bdrm. Direct cable connection to the Vizio and autoprogram did not pickup all the HD channels available off the box, like ESPN and 2 and the local FOX and CBS feeds. I understand this is to be expected, correct? May I ask for a brief explanation why?
However, direct hookup to the Sony and autoprogram: still no ESPN or 2 but did pickup the CBS and FOX feeds. Does that mean the Vizio tuner is inferior and should be returned?
Lastly, this situation where you can't get all the HD channels without the box, does that go away with the Feb conversion?
Appreciate your thoughts and help in advance.
I would have expected you to receive the local FOX and CBS feeds without a cable box on both TVs. Have you tried "tuning" the vizio to the channel that shows up as FOX and CBS on the Sony? Perhaps the autoprogram didn't pick it up but it is still there?
As to ESPN not showing up... It is encrypted by mediacom so that you have to have a cable box to decrypt it. I believe they are restricted from encrypting the regular network channels?
I don't think the Feb conversion has anything to do with your HD channels issue. My understanding is that they will stop broadcasting analog stations over the air. Which to me means that the majority of people will not really see a change in anything. (Only those who don't subscribe to any form of cable or satellite service will be affected... correct me if I'm wrong someone.)
post #153 of 815
I'm a Mediacom customer from northwest Iowa. Currently we have HBO, Starz, Showtime, The Movie Channel, HDNet, CNN, ESPN, HD Theater, Universal HD Movies, FOX SPORTS NET, TBS, TNT, CBS, and FOX all in high definition available. They have advertised more to come this spring as well. I also have in use the new PACE Tahoe TDC779X box that Mediacom has started to offer. Using an eSATA HDD or eSATA enclosure, you can add more recording space via the external SATA port on the back of the box. I'm currently using a SATA enclosure with an internal 750GB Seagate HDD. It gives me around 90 hours of HD capacity. Just thought I'd pass this along.
post #154 of 815
Noooooooooooooooooooooooooooo!!!!
post #155 of 815
Any word on if (or when) the Cedar Rapids area will get WGN HD? GO CUBS!!!!!!!
post #156 of 815
Public television, IPTV, is not listed on my hd guide anymore. Anyone know more about this?
post #157 of 815
central illinois (paxton) area has WGN HD-725 on now. no guide info or channel name but on nonetheless.
post #158 of 815
I have yet to get any video on KCWI-DT via Mediacom on central iowa.
post #159 of 815
on the guide now. watching wwe smackdown in hd tonight!
post #160 of 815
Hey, jpark! Have you noticed that the signal is breaking up more on other channels since mediacon added WGNHD? I have noticed it on both Fox (707) and ABC (715) but am not sure if it is just my setup or a problem system wide.
Mel
post #161 of 815
haven't noticed. will watch for.
post #162 of 815
I'm wondering the same thing..I'm glad that comcast is in HD so I can at least watch half of the games in HD but I'd really like WGN. so....anyone know?
post #163 of 815
Haven't heard anything in Iowa City. Don't forget. The Cubs are on Mediacom's connection channel tonight.
post #164 of 815
my wgn hd channel lists shows that are on another wgn. take for instance last friday, the 18th. at 7:00 PM it listed wwe smackdown which is on wgn/cw, but it showed Elizabeth instead, the same as what was on channel 9, standard wgn. wtf! hopefully they get this straightened out. i'll wait to see what then i'm gonna give them a call if it's the same.
post #165 of 815
I just got my cable hooked up today and when the guy was hooking it up I asked him about WGNHD in Cedar Rapids. He didn't know about WGN but supposedly they are going to have a significantly larger number of HD channels soon ( I think he said 90) We'll see about that though.
post #166 of 815
Mediacom, Bresnan To Take Some Small Systems All-Digital
Agreements With FCC Allow Systems To Deploy Set-Tops With Integrated Security
By Todd Spangler -- Multichannel News, 4/25/2008 11:43:00 AM
Mediacom Communications and Bresnan Communications will convert some of their small rural systems to all-digital by the February 2009 digital TV transition date, in agreements with the Federal Communications Commission that will allow those systems to deploy set-top boxes with integrated security features.
Mediacom will convert 29 systems in Arizona, California, Kentucky and Mississippi, while Bresnan has pledged to eliminate the analog channels in its 625-Megahertz system in Gillette, Wyo.
Mediacom in January petitioned the FCC for an emergency waiver to the so-called integrated set-top ban for those systems, arguing that it may have to shut down some isolated systems otherwise.
Bresnan, meanwhile, in a December filing to the FCC said it could triple its high-definition lineup in 2008, to offer 50 HD channels, if it could eliminate the analog tier in the Gillette system. However, the operator said, it would only be able to do this if allowed to deploy lower-cost integrated set-tops.
The FCC, in an order dated April 16, granted those waiver requests.
Since July 2007, the FCC has required most cable operators to deploy set-tops with removable CableCards. By agreeing to move to all-digital operation, the Mediacom and Bresnan systems will be allowed to use lower-cost integrated set-tops.
Video customers in those all-digital systems will need a digital set-top to receive programming. Both operators told the FCC they will notify analog-only customers of the transition by mid-June and ensure that they have sufficient inventory of digital set-tops for those customers by then.
Mediacom vice president of legal affairs Tom Larsen said all-digital operation will allow those systemseach of which run at less than 552 MHzto enhance our service offerings in these systems.
We will immediately be able to expand the number of HD channels. The extra bandwidth will give us the freedom to offer more programming tailored to the local market, Larsen said.
For example, Mediacom will be able to add more Spanish programming in its Arizona systems. Down the road, Larsen added, these systems will have the capacity to move to DOCSIS 3.0.
Larsen said Mediacom is still finalizing our transition plan for these systems, but I anticipate that we will make a certain number of free low-cost boxes available to each household we serve during the transition period.
In Gillette, Wyo., Bresnan will eliminate 63 analog TV channels and reclaim a net of 250 MHz of spectrum. The company has not announced how it will use the freed-up spectrum or the details of how it will distribute the Motorola DCT700 digital set-tops to existing analog customers.
http://www.multichannel.com/article/...?desc=topstory
post #167 of 815
50 channels would be nice to see.
post #168 of 815
I just wish Cedar Rapids would put PBS back on the Guide. I dont know why they took it off.
post #169 of 815
We are expanding our free HDTV programming tier with more channel adds and most of our systems are more than halfway to our goal of having up to25 free quality HDTV channels by year end ad we are also beginning to see greater utilization of our newly launched HDTV movies on demand as well.
http://seekingalpha.com/article/7947...sitemap&page=4
post #170 of 815
well according to our bill WGN HD was supposed to be added to our lineup in eastern iowa/western illinois today.... No go
they did however remove a bunch of the redundant starz/encore channels... hopefully a sign of good things to come
post #171 of 815
History and A&E added to our HD lineup today..
post #172 of 815
I really hope those are added in DSM before the season finale of Ice Road Truckers.
post #173 of 815
i've really enjoyed HistoryHD.. I had kind of strayed from watching History since it wasn't offered in HD.. Nice to have it back
Bring on the discovery channels!!!
post #174 of 815
where are you in central ill? what channel numbers are they? i see nothing on my guide yet. i know the standard def versions are channels 30(A&E) and 34(History).
post #175 of 815
im in annawan, il about 40 miles east of the quad cities via I-80
channel numbers are 747 for A&E 748 for History
The addition of the channels were a surprise to me.. We had a huge storm
come through town and we were without cable for 3 days.. When we got hooked back up low and behold there they were.. We still haven't seen the WGN channel added like a previous post ^^ mentioned.
post #176 of 815
DSM area - try channel 838. USA HD.
post #177 of 815
WGN HD ch 825 and USA HD ch. 838 up in Iowa City.
post #178 of 815
usa hd on in champaign, il area. waiting for others to appear.
post #179 of 815
USA (ch 738) and SCI FI (ch 739) added tonight
post #180 of 815
I see on http://www.mediacomcc.com/cable_hdtv.html that if I have advanced HD receiver or cable card, automatically receive the HD Family Basic channels at no additional charge.
What does the HD receiver or cable card cost? I have family cable at the moment and get some HD channels with my QAM tuner.
  Back to Forum: HDTV Programming
