Are you using an HDHomeRun and a set top box? Or just the HDHR? I called my provider today and he didn't know what channels were and weren't unencrypted QAM but he told me I had to use their STB and I could not use anything else in place of one.
I wanted to just use the HDHR but it seems like if a lot of their channels are encrypted (from what he said maybe all of them are, but that doesn't seem very likely) then I'd have to keep an STB around for the encrypted ones.
Is everyone with an HDHR using MythTV? I read it doesn't work with MCE, is that still true?
They also told me that I have to use their cable modem, I can't buy my own, which as far as I know is BS, so maybe he was just an idiot.
I've seen posts saying that sometimes the regular network channels are the only channels that aren't encrypted. If that's the case then there wouldn't be much point in using an HDHR, right?
I've been trying to justify putting together an HTPC, but it seems like almost anything I put together is going to be gimped in some way. The main two things I want to do are use it as a DVR and also do away with physical DVDs and watch them all from a hard drive. It seems like an HDHomeRun setup will be much more expensive and much less functional than just getting a DVR from my cable company and using my 360 to stream movies from my regular desktop PC. What format do they need to be in for that, BTW? I just started digitizing my DVD collection and I've just been leaving them in folders as IFO/Mpegs, will the 360 work with that?
