Ok so i just upgraded from an Infocus X1 to a Mitsubishi HC1500 and i couldnt be more satisfied.
The only thing that bugs me is the startup sequence... I just wanna know if its normal, as the infocus did not do it.
So when i start it up, its like its starting itself, then seems to "stop" (the fans seem to stop) then it starts again and then the lamp starts up.
Is this normal behavior from this projector?
Thanks for any help!
