Originally Posted by Rutgar
No, actually it doesn't. You're changing the argument. If you want to prove there is a 'placebo' effect, then yes, you use the same cable, while telling people they're different.
But if you want to prove there is or isn't a 'real' difference between two cables, then you have to use the two different cables in question. The only place where the placebo effect comes in to play, is that the test must be set up to rule it out.
No, I'm not changing the argument. I think the existence of the placebo effect is well established. There are claims of great sonic differences among cables that have infinitesimally small electrical differences. When those sonic differences are reported only in sighted tests but vanish in double-blind tests, it's a good example of placebo effect, as well as expectation bias and other influences.
? Try
, those links aren't working for me. I'll do some googling with those search words.
