AVS › AVS Forum › Audio › Receivers, Amps, and Processors › multiroom audio from computer
post #1 of 4
i will be using a yamaha 1800 receiver, with the zone 2 presence coming off the yamaha amps, and zone 3 will be output to a separate amplifier.
1. am i correct that i have to connect each of the input sources via analog connections to be able to distribute through zones 2 and 3?
i plan to connect with both digital and analog connections to the receiver from each source so i should be ok, but the problem i run into is with my computer sound card. it only has a digital output.
2. what would i have to do to be able to play the computer music throughout all of the zones?
thanks for the help guys
post #2 of 4
anyone?????
post #3 of 4
post #4 of 4
