AVS › AVS Forum › Audio › Speakers › My Journey to find the "perfect" speaker...
My Journey to find the "perfect" speaker... - Page 103
post #3061 of 6914
Originally Posted by hifisponge View Post
I was begining to think that I was alone in my desire to "beautificate" my gear. Good to hear that I'm not the only crazy one around here. I have to say that every time I walk by the left speaker to leave the room I have to stop and stare for a moment. I did my best to capture their magnifigance in the pictures, but you really need to see them in person.
You mean to say you have not put them on Youtube yet to show them in all their glory?
You slacker
Cheers
DT
post #3062 of 6914
You slacker
Cheers
DT
I'm working on geting onto the next episode of MTV Cribs. But instead of having a half dozen exotic sports cars parked out front, I'll just have to have the Studio2's sitting in the driveway.
post #3063 of 6914
We should rename the thread to:
Tim's Journey to find the "perfect" speaker(s)...again.
HAHA! "I keed, I keed!"
Seriously, though, you've had quite the experience, but have been rewarded in the end for your hard work, even if it was getting to the point of annoyance for you at times. Well done, Tim. Well done. I hope to get where you are soon.
All joking aside, I want this thread to be more than my "journey." I want this thread to be used as a time line of events for everyone and their search for their "perfect" speaker. Please don't let this die now that Tim and I are content. The journey continues, but now it's your journey folks.
post #3064 of 6914
Originally Posted by QueueCumber View Post
You are right...
I am so close to the tail end of it, that it isn't too bad anymore though. Now it is just waiting for replacement equipment to arrive so I can finish the final details...
Though, adding additional subs is a new consideration, it isn't going to make or break my room at this point like some other issues did.
Hey QueueCumber,
Did you check out Tim's "Acoustic Cloud" thread:
http://www.avsforum.com/avs-vb/showt...5#post14260925
I daresay, an acoustic cloud in your room would be a whole lot less *visual* than the absorption/diffusion treatments you have there now. Using Tim's RPG BAD Panels, you get absorption and diffusion without the "stalactite" look:
http://www.rpginc.com/products/badpanel/index.htm
Of course, if you *like* the pink stalactite look...
Not that there's anything wrong with that...
Craig
post #3065 of 6914
I like it. It matches his speakers. All looks very otherworldly.
post #3066 of 6914
It is actually much more red than it looks.
Believe me, if Rives felt they could achieve the same with an acoustic cloud than they would of. They spent considerable time laying out the room.
post #3067 of 6914
You guys know each other? Perhaps in a "personal" way? HAHA!
post #3068 of 6914
I only know Jeff via here. I just take the time to research and know about someone's system before commenting on what they should do differently. I think that is a bit too presumptuous.
post #3069 of 6914
Hey QueueCumber,
Craig
So Rives Audio did this room, interesting...
post #3070 of 6914
If Rives a local shop to you, Ryden?
post #3071 of 6914
No, they are closer to you. I believe they are in Iowa? but I am not positive.
http://www.rivesaudio.com/
http://www.rivesaudio.com/home/home.html
post #3072 of 6914
Interesting. Thanks bro.
post #3073 of 6914
Hey QueueCumber,
The "stalactites" are mostly diffusors, not absorber/diffusors. Though, those other panels up there around the "skylines" are BAD panels which are used for reflection points on the ceiling.
I didn't have much of a choice with the ceiling. BAD panels alone are too absorptive for the entire ceiling, though they are great for 1st order reflection points. In any case, I couldn't do something like an acoustic cloud. My ceiling was built right on the joists of the basement ceiling in order to get as much height in the room as possible.
If I had my way, I would have done coffers with some BAD panels in key reflection areas, but I had to work with the space I had. The most height I could get in the room was 9 feet, and that was by putting drywall right on the joists... Rives was interested in preserving room volume, which is why the symmetry of the space was sacrificed as well (one side has a larger soffit because of a metal support beam). I actually describe a lot of the reasons why things were done a certain way in my HT Build thread.
Craig
It is New London Burgundy. I apologize for my poor picture taking skills. My wife picked the color; she is a designer. I deferred my choice of "black" to her choice of "burgundy." It involved her in the process and she has a degree in graphic design from Parsons.
The general color tone of the room is actually a lot darker with how the lighting is set up, but in those pictures the flash on the camera is changing the look and feel.
Combine the lighting in these two photos and you get closer to the character of the room:
I'm not a photographer by any means though...
post #3074 of 6914
For instance, though the "stalactites" look like a different color than the ceiling on the photo you posted, in person they are the same exact color. I had them matched exactly. It is a testament to how little I know about taking pictures...
This photo shows that a little better...
Then of course, it gets darker as I dim the lights using the Lutron Grafik Eye as well.
post #3075 of 6914
It sure is a sweet room though, Que. I hope to have something like that in 10 years or so. Enjoy!
post #3076 of 6914
Thanks. I had to make a lot of compromises. Ones I didn't want to make.
I would do A LOT of things differently if I could go back in time, such as optimizing the room for 2.35:1. Heck, I would even have shopped for a house differently if I knew then what I know now. When I bought this new house, I didn't even consider doing a home theater, it sort of progressed out of my desire to get back to my high school days when I had a JBL/Carver system in my bedroom. I would have bought a house with much higher basement ceilings, or a room upstairs that I could have used for a home theater.
This current room was optimized for two channel. The HT part was an afterthought that took on a life of its own as time has gone on. If I had designed this room for multichannel 2.35:1 HT from the start, it would be a different beast. Ideally, my next home would have space for a decent sized two channel setup, and a very very decent sized HT with 2.35:1 and reclining theater seating.
I can say that this room is livable, even for a perfectionist. I just had to resign myself to the HDTV 16:9 ratio I originally chose because I didn't know that movies were another ratio, or that projectors could display in that other ratio. Live and learn... I'm not unhappy with how things turned out though, I just would do it differently because my understanding of my own HT needs have changed as I became more edumacated.
post #3077 of 6914
Que
It's still a gorgeous room, even with the compromises you mentioned. Wish I had the space, I'm doing it all in a combined 2-channel/HT in the family room.
Mark
post #3078 of 6914
Originally Posted by golfugh View Post
Que
Mark
post #3079 of 6914
Que
Mark
Sounds familiar.
post #3080 of 6914
I feel very fortunate to have this space and to be able to do everything I have done to it already. I do think for the money paid to build the room itself, I should have done the Rives Level 3 instead of Level 2. Penny wise, pound foolish... My advice to anyone who is going to do something dedicated at some point is not to try and do things the cheap way, it always ends up being more expensive in the long run!
post #3081 of 6914
Maybe we can arrange for Que to loan you his Lotus and me to loan you my Aston Martin -- total pimp job.
post #3082 of 6914
You are my hero. Aston Martin is my dream car. But I had to chose one love over the other, and the sound system won.
Which model do you have?
post #3083 of 6914
I envy those of you have space in your house to create a dedicate music/HT room...
I was about to buy a 4,000 sq. ft. house in Houston last yr w/ a spare family room upstair for music/HT..
What I ended up doing was moving back to bay area..bought a house for twice the price and half the space..
It's a really struggle to balance the acoustic treatment for music/HT and not effect the primary function of the living room..
The more I thought about it, the more I find Tim's approach & solution more impressive...
-Paul
post #3084 of 6914
-Paul
Yeah, I certainly never thought I would treat this room. Part of it was wishful thinking that I would not live here long enough to want to do it and the other part was that there seemed to be no unobtrusive way to do it. Never thought to look up for the answer.
post #3085 of 6914
It is a beautiful room and I'm sure it sounds excellent. Once you get your Denon pre/pro and run Audyssey, you'll probably no longer regret not getting the Rives Level 3. Check out the "Official" Audyssey thread:
http://www.avsforum.com/avs-vb/showthread.php?t=795421
If a standard MultEQ XT calibration isn't sufficient, you can always get a "Pro" calibration.
The burgundy color theme is excellent for an HT environment. (The photo I linked did make it look pink. ) I have a burgundy color scheme in my room as well, and I too involved my wife, (who owns a home decor shop) in the design process. She hand-made the burgundy velvet drapes that cover the front wall acoustic treatments, and she helped me cover the side wall panels in matching burgundy GOM. The carpet is a dark brown and the ceiling is a dropped acoustical ceiling with black tiles. When the lights go out, the burgundy drapes and panels disappear and the front of the room becomes a "black hole" with the image suspended in in it.
BTW, is your screen acoustically transparent? If so, you want it down when you run Audyssey as it will compensate for any HF losses through the screen. It worked very well with my SeymourAV AT screen.
Craig
post #3086 of 6914
Craig
I get the same black hole behind my screen as well because of the color choice.
(More of my superior photography skills at work - notice the slight lean to the screen in two dimensions - I believe Eisenstein would call that visual conflict - very artistic... Definitely superior to a gorilla's photography skills, though perhaps not a well trained chimp!)
I do have a Stewartscreen acoustically transparent screen. I am going to do measurements with it up and down to see how much of a difference it makes. Then I will try Audyssey measurements with it up and down and see which sacrifices the least in response and then base how I EQ on that. If the screen being down has a negligible effect on the sound (which I have heard about the Stewartscreen AT screens), then I will likely do all of the EQing with the screen up. If at some point Blu-Ray becomes more productive with its video concert output, I'll switch it around.
post #3087 of 6914
I would put the newly painted R logo as my avatar to get those purist blood boiling
man I have to say I have seen anything this beautiful in a long time, well I'm lying there are tons of gorgeous lady in the NY these days, I'm falling love very other 5 minutes rivaling my audio hobby( Hmm I wonder what hobby is more expensive )! But never the less I'm loving the paint job.
DJoel
post #3088 of 6914
Women take years off your life! They incur a much greater cost to your life expectancy than HT...
post #3089 of 6914
Meh!.. It might just explain why I'm prematurely grey
Djoel
post #3090 of 6914
Gents -
Although I currently have speakers, I am going to do a little rearranging when the Song Tower's arrive. My goal is to achieve the ideal location for the speakers, but also improve the bass response, of which I'm not happy with concerning my current speakers. My room is about 12 x 25 with a smaller 10 x 12 room off to the right of where the front right speaker sits. See the diagram below.
I am planning on trying the WASP method, but I was hoping to try something easier first. Does anyone have any experience with this method?
http://www.cardas.com/content.php?ar...ing=Room+Setup
Any suggestions are most appreciated. Right now my Rocket's are about 2 feet from the back wall and the left speaker is 2-3 feet from the left side wall. Nonetheless, the bass response is not that great as I think I have a null at the listening position (speakers are about 8 feet apart and the listening position is about 10 feet away).
Please help and/or give suggestions. Thanks all!
  Back to Forum: Speakers
