Nuance -
Hey, Tim here. Interesting to see that you are still on the hunt. I thought this thread was dead after you picked up the Rockets. I know just what you are talking about when you say that the hunt is almost as fun as finding what you want. I get the feeling that you and I aren't not alone here.
I enjoy reading your take on the speakers you listen to because I can tell you are impartial, unlike the comments made in the numerous "owners" threads. Of course those people like their speakers, that's why they bought them.
Choosing the Sierra's over the Dyns is proof alone that you are unbiased or influenced by the it costs more, therefore it must be better POV. Refreshing.
I hope you don't mind if I give you some feedback on a couple of comments you made. You mention that the Sierra's lacked an open, airy sound, and you give a loose theory that it may be due to the small size of the speaker. Actually, "air" and openness are a trait of the HF response, extension and dispersion. Air comes from the upper most high frequencies (10-20 KHz). If the tweeter has limited off-axis dispersion, in a moderately furnished room the upper most treble will sound rolled off. The size of the speaker has no impact on its ability to sound open and airy, only the performance of the tweeter. You also mention that the midrange sounded a bit recessed, but make the statement that crossing the speaker over to a sub would probably change this. A midrange that sounds recessed actually comes from a dip in the lower treble / upper mids (800Hz - 3KHz), which is well above the 60-100Hz crossover point used for most subs. Now had you said they sounded a little thin, lean or dry, then a sub can help with this a bit.
One last thing. Like many high-end speakers, when you buy the Dynaudio's, you aren't just paying for potentially better sound quality, you are paying for the added cost of the speaker being manufactured in Denmark rather than China, and you are paying for the name and reputation of the brand.
As you know from some recent PM's between us, I just plunked down a large sum for a set of Focal Electra Be speakers. I am at the point in my life that I can afford such luxuries (barely
), but I know that a large part of the cost goes into the beautiful cabinetry and the fact that they are still made in France. Heck, I wish they were made in China, as it would have probably cost me half as much.
Cheers,
- Tim
Choosing the Sierra's over the Dyns is proof alone that you are unbiased or influenced by the it costs more, therefore it must be better POV. Refreshing.I hope you don't mind if I give you some feedback on a couple of comments you made. You mention that the Sierra's lacked an open, airy sound, and you give a loose theory that it may be due to the small size of the speaker. Actually, "air" and openness are a trait of the HF response, extension and dispersion. Air comes from the upper most high frequencies (10-20 KHz). If the tweeter has limited off-axis dispersion, in a moderately furnished room the upper most treble will sound rolled off. The size of the speaker has no impact on its ability to sound open and airy, only the performance of the tweeter. You also mention that the midrange sounded a bit recessed, but make the statement that crossing the speaker over to a sub would probably change this. A midrange that sounds recessed actually comes from a dip in the lower treble / upper mids (800Hz - 3KHz), which is well above the 60-100Hz crossover point used for most subs. Now had you said they sounded a little thin, lean or dry, then a sub can help with this a bit.
), but I know that a large part of the cost goes into the beautiful cabinetry and the fact that they are still made in France. Heck, I wish they were made in China, as it would have probably cost me half as much.Cheers,
- Tim
For that price I could pick up a pair of Vandersteen 2CE Sig II's and a MFW-15 subwoofer.
