AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Software › PS3 and Fantastic Four 2 issues
post #1 of 4
My PS3 isn't playing the Fantastic Four 2 blu-ray dvd, it tells me I need to use a region b player. Other region b films worked fine in my region a player before, but now...
I understand, that region a is usa/japan, and region b is european, and thus should not work in the wrong region player, but mine did, and now it seems they have prevented this from happening in this new blu-ray release. I'm not all that fussed, just a little dissapointed. Just means, I will have to buy an import, or is there a fix?
Yes, I am in living in the uk with a region a ps3, but that's because I got mine cheap
Oh well.
post #2 of 4
No offense, but I fail to see how a Region A player not playing a Region B movie is an "issue." That's kinda the whole point.
Are you sure the discs you thought were region B that worked were actually region B and not Region ABC, instead?
post #3 of 4
It's just a small minor issue for me, spending money on stuff thinking it will play, universally not everyone is a stupid as me.
You could be right about the ABC thing though, Casino Royale is ABC isn't it? I bought it from a local shop and it played fine.
post #4 of 4
So far no Fox releases were regionfree.
  Back to Forum: Blu-ray Software
