I watched the Sunday games (Go Chargers!) and I have to tell you that even with the COX feed, it looked great. I wouldn't base anything on the Sams Club feed. PLus the out of the box set up on this set is just weay too bright... looks very washed out. The 6070 is a 720p native set and is likely to be more forgiving of poor signals. Also individual cables to each TV in there are likely to be suspect. At times, I see the HD TV's hooked up via composite or component cables split many ways. Even if they are using COAX distribution, there is very possibly poor terminations or cables run next to noise inducing components. Bottom line, unless you can go through the menus with the remote and QC the hook up, there is no good way to tell. Talk to the head of that department to try and assess their A/V competence to get a feel for the set up.
See if you can talk them into letting you play with the remote and hook it up directly to a blu-ray player with a good test disc. Good luck...
Originally Posted by wpwj40e
Hey Guys....Checking this out at SAMS, saw a bit of pixelation. They have a 6070 right above it and that pic looked clean. Where it was most noticeable was some shots for the upcoming Olympics.
How is fast motion on this set....football...etc. Did you watch any of the wild card games or can you report after this weekends playoffs. Concerned with the triple ball effect on long pans and motion.
There appears to be quite a bit to like about this set....motion is the concern.
Thanks!!
Thanks!!
