AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Official Pioneer Kuro Pictures Thread.......
Official Pioneer Kuro Pictures Thread....... - Page 185
post #5521 of 7297
Originally Posted by saprano View Post
Put the image code between this-
[IMG] [/IMG]
That will work for pictures on my computer or do I need to put them somewhere else first?
post #5522 of 7297
Flickr, ImageShack, there are many free hosting sites.
post #5523 of 7297
Cinéma " Le Corniaud " ( BD ).
BD320/Kuro ( BR ) :
post #5524 of 7297
post #5525 of 7297
post #5526 of 7297
Cinéma " The Untouchables " ( BD ) .
BD320/Kuro ( BR ) :
post #5527 of 7297
post #5528 of 7297
post #5529 of 7297
noticed after 2 year usage that KURO black had turned into a redish glow
any more people with the same problem?
post #5530 of 7297
Yup, but not sure if it's a new thing. I remember seeing a bit of red after a few months of owning one.
post #5531 of 7297
I just noticed this problem on my KRP-500M like a month ago. Which display do you have? I noticed it in the letterbox bars during a dark movie in the pitch black. If there are any lights on in the room it is hard to tell and if the screen is very bright then it is hard to tell. I have been trying to find out what the problem is and if there is any way to fix it as this is very saddening
post #5532 of 7297
I have a 5090H, bought mine 2 years ago at a vision+ dealer. Pioneer will send repair guy within the next week. Will keep you informed.
post #5533 of 7297
Is yours still under warranty? The problem for me is that I am no longer under warranty. Please do let us know what the repair guy has to say about the issue. This same problem has been brought up in multiple forums and threads.
post #5534 of 7297
I've had my kuro 500m for almost 2 years and I have not seen the red tint you describe and show. Have you discovered any ideas or possibilities through research what might cause this?
Also guys, what build date and model do you guys have? I have an October 2008 builddate Krp 500m. That might clues us.
post #5535 of 7297
This issue has cropped up for a small number of us Kuro owners. Seems to affect all models/sizes 9g, 9.5g. There is no known solution. I had my A-board replaced, that did nothing. There are a few more posts regarding this issue in all of the other Kuro threads, save, I think, the Signature Elite 141 thread.
Your case is by far the worst I have seen. Mind you, I have only seen my own, and photos of 2 or 3 other members sets. The majority of the reddness it seems, starts from the bottom right hand corner, and progresses outward and upwards, then begins anew at the top of the set.
If your tech has any insight into this issue, keep us posted, thanks.
post #5536 of 7297
Yes, that is exactly how mine started as well. The affected area on my 5020 is about half as much as the picture above, with only the middle of the screen un-affected. Mine is not quite this bright. I've called the person who professionally calibrated mine, he would not even consider coming to look at it. $175 an hour, with no hesitation, NO!!!
post #5537 of 7297
While probably not helpful I don't have anything close to resembling that. i see no red tint at all. I have a PRO151FD that I have had since November of 2008.
post #5538 of 7297
I know that on the picture the red is overdone in real life it is no so red. Had to use long shutter time to get a decent picture. So there is no repair for this, guess i am getting a brand new tv from Pioneer, or replace the screen. Bought mine at a vision+ dealer so i got 3 years warranty.
this one is less red
post #5539 of 7297
whats the point of just posting pictures of the image on the screen only? i want to see kuros as a part of peoples home theater system, not stills from a film... boring.
post #5540 of 7297
Nice pics urga!
post #5541 of 7297
Originally Posted by Urga View Post
Hello ,
Kuro EU TVHD Sat PAL system , no NTSC .
sorry Urga but I mean for example:
Picture Mode: ?
Contrast: ?
Brightness: ?
Colour: ?
Tint: ?
Sharpness: ?
DRE Picture: ?
Black Level: ?
ACL: ?
Enhancer Mode: ?
Gamma: ?
Colour Temp: ?
CTI: ?
Colour Space ?
Noise Reduction Options ?
post #5542 of 7297
So is a repair guy still coming out to check out the TV or why do you say there is no repair for this?
post #5543 of 7297
Picture Mode: ?
Contrast: ?
Brightness: ?
Colour: ?
Tint: ?
Sharpness: ?
DRE Picture: ?
Black Level: ?
ACL: ?
Enhancer Mode: ?
Gamma: ?
Colour Temp: ?
CTI: ?
Colour Space ?
Hello ,
TVHD 1080i 75Hz :
Picture Mode: User
Contrast: 27
Brightness: 0
Colour: -4
Tint: G +1
Sharpness: 0
DRE Picture: Low
Black Level: Off
ACL: Off
Enhancer Mode: 1
Gamma: 3
Colour Temp Manual :
Rh : -3
Gh : 0
Bh : +2
Rl : -1
Gl : -1
Bl : + 1
CTI: Off
Colour Space : 1
Noise Reduction Options : Off
post #5544 of 7297
That is the point of the entire thread. It isn't a "what is your set up" thread. It is pictures of what a Kuro can produce on screen. Literal Kuro pictures.
post #5545 of 7297
@ Urga
ok thanks, I also prefer the visual the color space 1, even if the reference is represented by color space 2, but the Gamma 3 seems excessive, more than 2
post #5546 of 7297
Hello ,
Trailers ( BD ) .
Pio BD320/Kuro :
post #5547 of 7297
post #5548 of 7297
post #5549 of 7297
@ Urga
You can't argue with the results he has achieved.
post #5550 of 7297
Excellent shots Urga!
