AVS › AVS Forum › Video Components › DVD Recorders (Standard Def) › New Walmart HDD/DVDR-Magnavox H2080MW8
New Walmart HDD/DVDR-Magnavox H2080MW8 - Page 16
post #451 of 943
Originally Posted by rh18 View Post
I've read through most of this thread and this may have already been covered but does chase play work on timer recordings? (Can you start playing back a timer recording while it's still recording and catch up?)
Yes, you can "chase play" a program that you are currently recording (works with both timer and one-touch recording modes).
post #452 of 943
Awesome, thanks.
However, I might have stumbled across a dealbreaker for me. Maybe someone can suggest something. This unit only has coaxial out for digital audio. My receiver only has optical input for digital audio. Anything I can do? (Get the Philips machine instead?)
post #453 of 943
Awesome, thanks.
If thinking about the Philips 3575, better get one quick... doesn't look like there's going to be anymore SDTV units with HDDs in the U.S. market. CES 2008 announcements in from Samsung, Toshiba and Panasonic.... none with HDDs so far.
post #454 of 943
Originally Posted by beekeeper View Post
It sounds like you have a signal problem so it is either the receiver in the maggi or the input to the maggi. My guess is it is wiring problem. I would try re-seating everything. Plus go through set up again.
I messed with the cable but made no difference. Watching the QAM channels was fine, there would be some occasional breakup in the signal, mainly in the HD feeds. The SD digitals were rock solid. Just wouldn't record. I tried going to DVD instead of the HD, same thing thought. Either a few minutes of video then black, or just all black from start to finish. The analog recording was fine though(except for the horrible picture). I just took the unit back to Walmart today. I liked the unit enough to give it another try, I just hope I can find one. For a new, relatively unique product, Walmart hasn't been stocking many. I don't know if this means they're selling like crazy or they just produced a limited number. There were stacks of the DVD recorder only models.
post #455 of 943
go to ebay and search for a coax to toslink converter I bought a toslink to coax converter for my audio system and it worked great and didn't cost an arm and a leg
post #456 of 943
So I have someone helping me set it up correctly... He removed my cable box entirely. So far, so good. We tested recording from tv to hdd and it looked great. Then dubbed to dvd, still great. This is such a big improvement over vhs!!
We are wondering if it is possible to watch a cable show and record a different channel at the same time? I know you can watch a hdd recorded show and record a different channel, but we couldn't figure out how to watch one "live" while recording another and we suspect it can't be done.
post #457 of 943
Thanks for the info. My Walmart had one of the Philips 3575 units left, so I just went with that instead of adding on parts to something else. This way I get double the hard drive and a few other features too! And the wife approved.
post #458 of 943
I'm not sure that's possible. I got the maggi for chirstmas and can't seem to chase play during recording unless it's the time shift mode.
post #459 of 943
I am able to chase play. Hit play while it is recording. See page 66 of the manual. I've used it for one touch recording and for timer recordings. Not sure but you can try hitting the title button to see if the current recording shows up there too.
post #460 of 943
This unit only has a single tuner so it will be dedicated to tuning to the recording channel. If you want to watch another channel, you'll have to use the TV's tuner.
post #461 of 943
Yes, the currently recorded show will show up in the title selection, and can be accessed that way also (for chase play).
post #462 of 943
I saw this last night myself. You can watch anything on the hard drive while it is recording including chase playing what is currently being recorded.
What I couldn't seem to do was stop the current timer recording. I had programmed a timer for longer than required due to possible football overruns. The recorded show was off and I wanted to stop the recording. I hit "stop" multiple times but it kept recording.
post #463 of 943
I don't have one the units you have but I have one of the maganvox zv450mw8 units that has the vhs dvd recorder no hard drive Last night I ran a dvd timer recording and had the same problem. On my unit (found info in manual after flipping through multiple,multiple pages) you have to press stop and the dvd eject at the same time (on the front of unit) to stop the timer recording Kinda nutty you'd think alls you had to do would be to press the stop or press the timer button to cancel the function.
post #464 of 943
Did you try pressing "stop" on the front of the machine (as opposed to the remote)? I think that works.
post #465 of 943
You're right! From the manual:
To stop the timer recording in progress:
Press [STOP ] on the front panel of the unit to stop
the timer recording in progress.
[STOP ] on the remote control is not effective.
post #466 of 943
I believe this is an excellent design decision, as it keeps us from accidently stopping a current recording while fiddling with the remote (and its ultra-small buttons). I never use the front panel buttons - except for the purpose of stopping a current recording. And I have advised my wife and kids to make all selections via the remote (philosophy being that it's cheaper to replace a damaged remote than a damaged DVDR/HDD). Thus, I have no fear of a timer recording being accidently cancelled, as it's impossible to stop the recording via the remote.
post #467 of 943
This "Stop" feature is good, Polo 2001G has it (prolly Polo 0161A has it too) and Philips 3575 has it.
post #468 of 943
Philips 3575 doesn't have it... Stop button on remote stops recording. If Chase Playing the recording or playing something else, one press stops the playback, but a 2nd press stops the recording.
I wish it did have a separate remote button to stop a recording, like my Pio 640.
post #469 of 943
you can stop a recording with the remote. you have to hold the stop button for a few seconds, and it will cease. oddly, it also powers down the unit on occasion, but not always.
stop on the front panel will stop the recording w/ one push.
post #470 of 943
I don't. It's a waste of a button for no good reason. I prefer the Philips system.
post #471 of 943
Originally Posted by jjvcary View Post
So...the tuner seems to be the culprit for the darker picture.
Yes, I don't think "tuner" is the accurate term to use, although it suffices well enough for me to know what you're talking about, especially since I've "seen it" directly ....
I'm not sure exactly what component/proccessing "step" is the culprit, My best guess is somewhere in the signal path after TS demux, and between the MPEG2 decoder used to decode source MPEG2 video stream and the MPEG2 encoder used to encode at 720x480i ... Besides resizing of 720p/1080i signals to 720x480, interlacing of 720p or 480p signals and ITU 709>>601 colorspace conversion for 720p or 1080i source signals as necessary, at present I can't think of anything else that needs to happen in there "between" the decoding of the original MPEG2 source video and the MPEG2 encoding for DVD, or why we're getting the significantly different black levels from video sourced from it's internal ATSC receiver ....
I've done much the same "process" which occurs(but as you might imagine with much better quality/results, especially as it involves programming orignally 24fps which can be IVTC'd or frames decimated to return it to 24fps via avisynth filters) via a PC using various software and HD broadcasts captured from ATSC receiver card for PC without ever experiening this issue nor ever having to, say, add a filter in AVisynth script to adjust luminance or "black levels". Of course, going through all that "on a PC" requires a lot more time and effort than using one of these DVD recorders ....
Nor have I ever had a problem with this involving the output of any ATSC receiver I have here or the DTV broadcasts from any local broadcaster, including ATSC receiver internal to a Sony HDTV which involves/allows "calibration" in a sense of it's "ATSC receiver input" via internal ATSC test pattern generator which is available via undocumented service menu feature ...
Anyway, Black levels from Magnavox H2080 or Phillips DVD3575H seem fine concerning the output and playback say, of "commerical" DVD's, or for that matter as encoded with the thing's MPEG2 encoder as sourced from it's analog s-video, composite, or Internal NTSC "tuner" ...
I would be helpful if others might note the quality of their picture via the tuner and a purchased DVD.
I have one H2080MW8, and one Phillips 3575H, and had to return/exchange a H2080MW8 for the one I have now because there was a problem with the component video output with the first one (occasinal corruption involving rolling "lines") .. BTW, I also had to open up the 2nd H2080MW8 because the door wouldn't open/was stuck because the (sorry for the lack of proper terminology I don't feel like looking it "up" currently) thing that has the laser on it and moves back and forth to "read"(or write on) the disc was "stuck" in a posistion it should not have been which did not allow the door to open/close ...
Anyway ALL 3 of them have apparently signifcantly incorrect black levels(too dark) only via the signal path that "processes" the signals from the Internal ATSC "receiver"(including after those signals are encoded and written to DVD or HDD).
So, The problem seems to only involve video sourced from the internal ATSC receiver ... I don't have/use cable, but assume the same is true as well if you're using the internal QAM demod instead of 8VSB demod for OTA ATSC ...
Surely, sometimes these things can be "off" and video output a little different from different devices, which is fine and not a big deal when all we're dealing with is the output from different devices and can "adjust" within service menus or input specific black level controls in our displays user menu "picture adjustment" options --- But, what we are talking about here is something that is "wrong" that is not only getting written to DVD or HDD, but is also sigificantly "different" than the black levels occuring and being encoded involving analog source video from the SAME device's S-video or composite (analog) inputs, AND the black levels from MPEG2 streams that are encoded on DVD's which are actually encoded "properly"(such as commercial DVD's) and as they are played back on the same device ....
Which reminds me, I also tried the same "test" as Voyager6 described earlier either in this thread or one of the Philips 3575H threads involving using a external DTV receiver outputing 480i and hooked to the Mag's S-video input and comparing it to "recording" made from the same source signal with either the Manavox or philips internal ATSC receiver (exactly the same recording/scenes etc regarding the philips internal ATSC receiver vs. external DTV receiver via S-video on the mag - I tried it the "other way" around as well, using the Mag's internal ATSC receiver+external DTV receiver hooked up to the phillips via s-video) --- and pretty much experienced the same thing he did ... Most importantly, I saw what I'll call "correct"(more or less) black levels via the external DTV receiver and via s-video input on the recorder, which was "way too dark" via the Internal ATSC receiver(s) ....
One can only fix this by adjusting black level accordingly on their display when viewing video souced "through" these DVD recorders internal ATSC receivers, which will need to be adjusted *signifcantly differently* for video sourced through the Philips or Mag DVD Recroders internal ATSC/QAM receiver vs. anything else(including when playing back a "commercial" DVD, or video, including as stored on DVD or HDD sourced from these DVD recorders S-video/composite Inputs OR it's internal NTSC tuner), and INCLUDING if that video is encoded/written to disc and then decoded later on A DIFFERENT DVD player ...
While it's "manageable", in a sense by adjusting display's black level controls anytime you view signals processed through the signal paths involved for these DVD recorder's internal ATSC receivers(again including if you're playing DVD's created on those on OTHER DVD players), and "returning" that setting to the correct value for any other source video :
It's bad IMO, and I don't really understand how they could have produced this product without "noticing" this problem, or in other words can't quite imagine such a product could have gotten into the production phase without them noticing such a significant issue ....
BTW, I hope I'm not harping on this too much, hope this isn't a little "too wordy" as other than regarding this issue, and these recorders not supporting writing correct AR info "i.e. 16x9 "flag" when 16x9 material is encoded (which seems kind of silly as easy as it is to do on PC, such as when I use a software based MPEG2 encoder to encode MPEG2 video, such as HC encoder/etc), I'm quite impressed with what these things can do for relatively low cost ....
This might help when making an appeal for a firmware upgrade to improve this. Thanks in advance
Hope some of this helps if you're in contact with them+appreciate your efforts if you are in contact with them ....
HOPEFULLY, a firmware upgrade or service menu adjustment of some sort is possible to fix this issue, but depending upon exatly what is going on, I'd guess it may be possible that it isn't possible and may require a hardware fix ...
post #472 of 943
Figured a couple of pics might be "better" demonstration than 1,000 words as in my first post, so attached as :
FromMAGdvd.jpg : A frame as encoded/written onto DVD by the MAG DVD Recorder(onto DVD which I then accessed using PC), recorded "through" the internal ATSC receiver ... All I did was add the jpeg compression. Source was ABC digital affiliate WCPO-DT Cincinnati during last night's ABC Broadcast of "the terminal". Note: I chose this frame for comparision as there was plenty of "dark areas" in it, and because it was easy to make sure I was getting the exact same frame for the comparison pics as there was fast movement occuring as Tom Hanks was moving a bag, and it was easy to use the window Pane in the background along with movement of the travel bag to detirmine exactly which frame it was, and because it was not combed(given the DVDrecorder is interlacing this and encoding at 480i/29.97fps) ...
Blacklevelasbroadcast.jpg : The Same frame as in "FroMAGdvd.jpg", but as captured as a transport stream from a PC card ATSC receiver - All I did was to add the jpg compression to post it here, resize it from 1280x720 to 720x480 using Lanczos resize, and convert colorspace from Rec. 709 as broadcast to 601. None of this effected the black levels vs. the case at 1280x720 .... Source was ABC digital affiliate WCPO-DT Cincinnati.
blacklevelcomparison.jpg - The above two pics resized into smaller pics and put in the same frame, for hopefully easier comparsion ... Top is "as broadcast" and is correct black levels/luminance/etc, bottom is via the ATSC receiver in the Mag DVD recorder (via Philips 3575H it would be the same), and is WAY too dark ....
post #473 of 943
I bought this unit today. I will give a complete review tomorrow. I have the philips 3455h for about a year and love the hell out of it. The new philips with the hdmi 1080p is dark like you guys get with the other systems atsc tuner.The new philips also doesn't have the time slip which is awesome if you forget to push record-it's always recording, so to speak.
This mag unit seems good price and I'll let you guys know. Only reason I didn't buy another 3455h is cuz the remote control signal would activate both units, and the mag is good price. I use hdd recorders for my home surveillance cuz one day someone stole my flowers.
post #474 of 943
Thanks for these comparison pics -
Rick
post #475 of 943
post #476 of 943
I noticed this difference in black levels for the Mag in recording OTA last month-definitely darker recording than source- reminds me of the first HDD panny that had it way back in 2002 I believe. Panny had to hardware fix it in 2003 didn't they?
post #477 of 943
Nitewatchman, excellent post! Thanks for the in-depth analysis. The darker picture does pose a problem. Although one can connect the player via both S-Video and Component and keep their color setting separate (with some TV). The programmes that we saved will forever suffer from the color problem.
post #478 of 943
Originally Posted by directory View Post
bought thus unit for my wife..
the cd tray didn't open. so, using the info i got on this thread, i opened it up --messed with the dvd tray gear--and now it works.
while it was open i also took pictures of the harddrive. its just a simple computer harddrive made by western digital.
now if i could only find out if i could swap in a 250gb harddrive inits place...anyone know?
3 pics attached. first 2 are of the harddrive itself. the other one is of the dvd tray gear that you play with to get it to open like normal.
Today I opened the Maggie and removed the drive. The drive in my Maggie is a Seagate ST380215ACE 80GB IDE drive. The drive is jumper'ed as cable select. The drive is mounted to a metal plate which is attached to the motherboard by three screws. The screws secure the drive the chassis. There is a ribbon cable with and IDE adapter that connects to the drive. The ribbon cable crosses the top of the drive and is attached to the drive with adhesive. You can carefully pry the cable off the top of the drive without damaging it. The adhesive is just to make everything neat. The standard power cable is attached to the back of the drive just like it is in a computer setup.
I hung the drive in my computer and it does not have a file system that is recognizable by windows. The system recognizes the drive as unpartitioned free space. From my IT background my guess it that this drive has a proprietary image and boot sector on it. Probably the only what to clone this drive would be to use Symantec or Norton Ghost with the -IR switch. This option will allow you to do a sector by sector copy of the drive. So you will get an exact copy. The resulting copy will be the same size as the original drive (80GB) so the best you might be able to do is have a backup drive around as you won't be able to resize the image. I did not try this as this method is slow and might take many hours to do. If someone wants to give it a shot and has the time to do it please let us know how it turned out. I think it might work.
I did try to hang a brand new unpartitioned Samsung 160GB drive in the Maggie. I fired up the the unit and all the HDD menu's are greyed out. When I try to record something I get a warning saying the unit can't record to this HDD. So my hunch is that the unit will only recognize a drive with the proprietary image.
post #479 of 943
I wonder if it is a linux partitioned drive you need to see if you can make the larger drive be partitioned in linux and then try it. Or at least run a pc with linux and see if can read the 80gb drive - sounds very interesting
post #480 of 943
If it is a linux partition you would still have to do a sector by sector copy unless you have an imaging software that read image linux partitions. The only software that I am familiar with that can do the sector by sector copy of an unknown partition is ghost. Perhaps someone else has a better way.
Given that my local store is out of the Maggie and the time needed to do the sector by sector copy I am not feeling it right now. If I blow my unit there is nothing for me to exchange it with locally.
  Back to Forum: DVD Recorders (Standard Def)
