AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › I need help connecting two subwoofers to one subwoofer output
post #1 of 8
I own a Klipsch RSW-12 Subwoofer and a Def Tech Powerfield 15 Plus. When I connect the second subwoofer(Def Tech Powerfield 15 Plus) to the
line out(Klipsch RSW-12) it seems like both subs put out less
bass. Why is that? Is there a way to fix this? I even tried a y-cable from the subwoofer output on the receiver. The same thing happens. I think the preamp level/voltage from the receiver isn't strong enough for both subs.
post #2 of 8
That is what it sounds like. It is being attentuated to much when split.
Do you have good quality cables? Sometimes a cheap Y can make a difference. We are talking very low voltage...
Can you just turn them up accordingly?
post #3 of 8
Did you calibrate each sub individually and you need to use a good quality "Y" cable.
Bill
post #4 of 8
Even if your receiver has no output level adjustment for the subwoofer, (if that's true put a new receiver on your Holiday shopping list ), there should be adequate output voltage to drive two subs -- if connected in parallel (as you are doing with the Y connector) each sub input will still see the full output voltage, perhaps less a small amount because of the lower total input impedance of the two subs in parallel.
A more likely scenario is that you have acoustic cancellation between the two subs. If either one of the two subs has a continuously varable phase control, try twirling it while bass is playing -- if just 0 or 180 degree switches, try both positions.
Your strongest bass, and your best blending of non-identical subs, and your easiest way to minimize acoustic cancellation, is to co-locate the two subs -- stack them or run them side by side.
post #5 of 8
Just split the sub output on the AVR and run seperate lines to each sub...DO NOT connect one sub to the other one...
post #6 of 8
All cables are Monster. Turning up the volume doesn't help either.
post #7 of 8
Bill
Yes
post #8 of 8
Tried both ways. I think the voltage is too low for both subs.
