AVS › AVS Forum › Display Devices › Digital Hi-End Projectors - $3,000+ USD MSRP › Panasonic PT-AE2000u review
Panasonic PT-AE2000u review - Page 6
post #151 of 444
Originally Posted by reio-ta View Post
She took out the filter and showed it to us and said it only needed to be vacuumed in order for clean operation! I know, a lot of help and very informative.
LOL, real informative. My experience has shown that dust will find it's way in over time and it's really annoying once it's noticed in the picture. You'd think these guys could solve this fundamental problem...
post #152 of 444
Agree, LCD units need a sealed light path. It must be more complex to do this though with a 3-chip LCD vs. a 1-chip DLP.
I really don't like Evan's comments on the AX200 vs. AE2000. The AX200 has a 1080p like picture? Either the AX200 is the best LCD unit ever delveloped or the AE2000 falls short on delivering image detail.
post #153 of 444
You have the opinion that the PC "reviews" are usefull. My opinion echo's Wet1's. At the end of the day, just like the PC "reviews", they are both just opinions, supported by very little facts.
That's true, and good to see we can agree on something . Anyway, I am very curious to see ALL the reviews as fast as possible because right now I'm projectorless and going nuts.
post #154 of 444
Why do you have your PT-AE1000u ISF calibrated when it comes as close as it can when using Color1 mode to being already calibrated: gamma is very close to 2.2, D65 is spot on, and all color coordinates are pretty much spot on too?
My ISF calibrator, Eliab Alvarez de la Campa, found that it was significantly "off" enough to warrant a good calibration. He's an expert in the field, and did an amazing job. I can totally see the difference, and would recommend it to anyone. I don't think there's many displays that come out of the box "perfect". Most everything could benefit from a good calibration.
post #155 of 444
What kind of screen do you have? Maker, gain and model, etc. Is your room a bat cave with black walls with no reflections?
post #156 of 444
This just in over at PJ Central. http://www.projectorcentral.com/proj...news092407.htm Sorry if this has been posted:
First, the AE2000 is showing as a magnificent projector, clearly the best home theater projector Panasonic has ever made. It is performing extremely well against the other 1080p models we have in house, and will be one of the strongest 1080p products of the fall season. Now, when we set it up against the AX200, here is what we find. First, in terms of resolution, the AX200 displays 1080p source material almost as cleanly as does the AE2000. In many scenes viewed side by side, especially those with lower inherent contrast, it is virtually impossible to tell which picture is coming from a 720p projector and which is from the 1080p model. In short, the compression of the 1080p signal into the 720p native pixel matrix on the AX200 is accomplished with surprisingly little loss of detail. This runs contrary to what you might expect, since the 1080p models are selling for several times the price of the 720p's. So you get the impression that loads of extra picture detail is what you are paying for when you buy a 1080p projector. This is not really the case. You do get a little bit more detail, but it is not nearly as significant as you might expect.
So, why pay the extra money? The truth is that the AE2000 smokes the AX200 in dynamic range. The black levels and contrast of the AE2000 are much better than those of the AX200. And the extra contrast gives the picture better definition, color saturation, and elegance, especially with material that is inherently high in contrast that pushes the limits of the projectors. Ultimately the AE2000 is head and shoulders above the AX200, in a completely different performance class. For the true videophile, it is no contest, and there is a clear reason to spend the bigger bucks for the genuine 1080p model.
Nevertheless, if you are on a smaller budget and want a picture that looks almost like full 1080p resolution, the AX200 does a truly astounding job at delivering the image detail from Blu-ray, HD DVD and HDTV. In buying the AX200 instead of the AE2000, you are primarily sacrificing contrast, deeper black levels, and the corollary effects of apparent image sharpness and improved three-dimensionality that come with higher contrast. But for the money, it is a bargain--you get almost 1080p resolution at a fraction of the price.
post #157 of 444
See the previous page, post 146 from yesterday.
post #158 of 444
Was this a paradigm?.....
post #159 of 444
Any problem using a 50 foot HDMI with the AX-200??? I need 35 feet minimum but I have a 50 footer now...Anyone??? Al
post #160 of 444
Wrong thread.
post #161 of 444
Originally Posted by RobZ View Post
I don't think AVS will carry these. Maybe we can get a ProjectorPeople group buy w/ extended warranty or similar incentive.
Yes, yes, yes!!!
Greg
post #162 of 444
Originally Posted by GrantMeThePower View Post
If it hits that price with rebates, i'll be stoked! I dont mind a rebate when its a thousand bucks.
I dont like the 2 dollar or 10 dollar rebate things...they aren't always worth the time. But 1000 dollars? then its worth it!
I think at this point the lamp life and price are my only concerns.
EDIT- BTW, THANK YOU DANIEL! I really really wish i could have made it out. Its only about a 20 minute drive from my place in south pas.
The problem with the $1000 rebate is you really sweat the whole time you're waiting for it, and there's always that very slight chance you'll never see it. Plus it wasn't avaialable here in Canada last time around. I absolutely hate the big-rebate policy.
Greg
post #163 of 444
Greg
yap, i am not a big fan of BS. rebate, not $1, not $100 and I will not buy Panny if they are pulling the $1000 scam again. But if they selling for $3k plus $1k rebate then i won't have problem with that....LOL
First you wait after 30 days to decide if the pj is worth keeping or malfunction before sending out the rebate, then you waste hours of calling, turn around and reissue proof of purchase after month of waiting... then you hope they will get it right the next month around. I prefer to douledown the $1000 on blackjack than the rebate scam. Yeah, it's scam to me.
post #164 of 444
Greg
You're absolutely right about the lack of rebate in Canada, which is total B.S.
But I dont understand about not getting the rebate...were some people not able to recieve them?
post #165 of 444
Originally Posted by Wet1 View Post
I assume it doesn't have sealed optics, correct? So what happens when (not if) you get dust in the light-path? Is there a port in the housing which compressed air can be used to clean it, or must the unit be disassembled to be cleaned? Not that it's that big of a deal to disassemble it and clean, but I know it will void the warranty if it's done at outside of an authorized repair shop. I'm not keen on sending my PJ in for two weeks every year to have it cleaned...
I'm using two PJ's currently, a (six year old LCD) Sharp XV-ZW99U and a (three year old DLP) InFocus SP-7205. Dust in the light path has plagued the Sharp projector since new although I followed the filter cleaning instructions. I shipped the PJ twice under warranty 1500 miles to get cleaned by factory authorized service-- factory cleaning helped somewhat (the specks were never completely gone) briefly, then dust specks appeared again uniformly across the image shortly thereafter. Now, out of warranty, I spray canned air as much as I can without major disassembly; this is to little effect and dust is an extremely annoying factor. By contrast, and used in the same environments, the InFocus DLP has never shown any signs of specks or dust in the projected image.
I want to get a 1080p PJ, and people are raving about this AE-2000u and it's hard to dispute the quality for the price. But the "dust in the lightpath" issue is of major concern to me and I'm wondering if this will be an issue with AE-2000u and if so, if it can be cleaned at home. If DLP is inherently less susceptible to dust intrusion, for example, I might lean (for more money) towards new InFocus IN82 instead. Thoughts? Thanks.
post #166 of 444
Wheeler,
Most DLP units have a sealed light path/optics. Most LCD units do not. So yes, dust is a real issue with LCD and very seldom an issue with DLP. Those who haven't had an LCD with this problem wouldn't think dust would be such a big deal, until it starts attacking your image...
I'm pretty much sold on this PJ, but the dust issue is still a MAJOR concern for me. My last LCD (a Sharp) had a lot of dust issues, despite the fact that I keep the filter very clean. It's been a long time since I've dealt with the dust issues, but I remember it being a major PITA. If this PJ comes in at around $2000-$2200 I'll probably buy at least one (if I like it, two). If it costs $3000 and has a possibility of dust issues, forget it.
There's a lot to like about this PJ (from what I'm hearing), but all the greatest specs and features aren't worth poop if the PJ has to be sent out/disassembled for internal cleaning ever month or two.
post #167 of 444
There's always that chance, no matter how small. I got burned with smaller items, like $10 off a keyboard or $50 off a router - send it in, don't hear back, call and told they don't have it, then it's too late, etc. I'd sure keep after them for $1000 of course and I've never heard of anyone not getting the money from Panasonic this year but... I just hate the whole concept of the mail-in rebate, which is based on hoping people will forget to send it in or that you can avoid sending the cheque until people forget, etc. Staples, for example, had all kinds of problems with these programs in the past (though again on much smaller amounts).
I'm with many others here... if it's $3000 straight up I'll buy it, if it's $4000 minus a $1000 rebate I just won't.
Greg
post #168 of 444
Same here.If panny pull's the $1k rebate scam,I will go another fp route,Hope they are listening.
post #169 of 444
Come on guys, I don't particularly want to create a point of contention here, but the poor English language gets abused enough without calling the rebate a scam. You don't like them...fine. Is there a tiny chance you might not get it.....sure. Is it a scam.........absolutely positively NOT. Scam implies that Panasonic has no intention of paying up, and while I, too, would prefer a lower price up front and no rebate, they are a legitimate marketing tool used by many companies in many different fields. Whew, I feel better now..................!
Dick Fogg
post #170 of 444
Dick Fogg
I just feel rebates are an unfair way to make interest, and "cook the books" almost, legally, in order to exploit a loophole in not being able to charge a certain price it never was. Rebates get accounted for on their ledgers differently than if they just outright charged $3,000 without paying a rebate later. The price sold is marked as $4,000, net revenue is $3,000, and the $1,000 for two months is free interest. So "scam" or not, it's not a nice thing to do, with the only winner the company providing the rebate.
So again sorry, and if you feel inclined post more to the thread! Ok?
post #171 of 444
I'll bow out gracefuly now so this doesn't get even more out of hand. Just for fun, why don't you look up scam in the dictionary (if you have one). That was the only point I was trying to make. And now, back to the Panny 2000.......I hope.
Dick Fogg
post #172 of 444
I'll bow out gracefuly now so this doesn't get even more out of hand. Just for fun, why don't you look up scam in the dictionary (if you have one). That was the only point I was trying to make. Oh, and thanks for using profanity in the first sentence of your response. So mature, so helpful. Really makes a person want to hang on your every word. And now, back to the Panny 2000...I hope.
Dick Fogg
This thread is becomig a scam
post #173 of 444
In what way? What part of my review was misleading? What part is illegal? What did I say which is untruthful? Would you like it if I just bowed out and didn't give any more reviews and observances on any other products in the future? In what way didn't I ever answer all questions, no matter how stupid I may have thought them? How much are you paying me to do this?
post #174 of 444
Chillax.
I am talking about the "scam" debate that has thrown what was an excellent and informative thread way off course.
post #175 of 444
Chillax.
Oh, ok. Well, for now I'm all out of answers that aren't here. I'm pretty much waiting for performance observances from people who buy, and I'm probably going to buy one myself once all the hype settles down and the price stabilizes.
I'll just tell you, I have one worry with the 2000u.
Movement, how well objects move, if there's major ghosting. Maybe the 24p issue really is with the projector. In the presentation Panasonic showed very little movement scenes, an NO FAST ACTION. So I'm a little worried.
That's about it, for the price, you won't get any better. If it's $3,000 soon after release, it's practically a no brainer, if motion's handled properly. All other factors in the projector get rated an A++.
So Panasonic, if you're reading, you better pay attention. A rebate isn't in your best interest at all, you have a very fine product. It would be a shame to see sales drop because you want to use the rebate, we'll call it "marketing tool."
post #176 of 444
If the pj is as great as you are saying, then it should sell fine at their MSRP. The competition is only a handful of pjs and some of those are more expensive. It may take a hit from the AVS crowd, but how many of their overall sales are from here?
reio,
How did you measure the color of the Panny?
post #177 of 444
reio,
"MSRP" is ~$4,000. Who in their right mind would pay that when the Pearl sells for about $2,800. Like I said, the PT-AE2000u barely beats out the Pearl, contrast wise, but smokes it for color accuracy. Again, you're talking about the AVS croud, they "might" care. But look at all those people who buy the JVC which isn't color accurate one bit, so much for "reference projector." J6P doesn't care about color, very few AVSers apparently do either. So why pay an extra $1,200 for the Panny, when you can get a higher status brand name like Sony? So no, it won't sell at all for $4,000. Also, the Sanyo is selling for $2,000. You could get two Sanyos for the MSRP. Then there is also the Mits, which is slightly over $3,000. Pretty much everyone who doesn't use AVS is an idiot, even some people on AVS are.
With my eyes. The cinema1 was very red and too green. Color1 looked spot on. Look at the Cine4home preview. Everything was spot on except yellow, which was a little too red. Compare that CIE chart to anything else out there OOTB. I haven't seen colors as accurate since the last time I viewed a professionally calibrated Viewsonic 1600x1200 graphics pro CRT monitor, who did desktop publishing.
http://translate.google.com/translat...language_tools
Color1
http://www.cine4home.de/news/PanaAE2000/Pic23.jpg
Cinema1
http://www.cine4home.de/news/PanaAE2000/Pic22.jpg
post #178 of 444
By the way, i pre-ordered this from projector people based on your review and other things i have read so far
post #179 of 444
I hope it works out for you! Be sure to post your findings.
post #180 of 444
Well, the Pearl is last years model. The BP is the new model and has a MSRP of $5495. That is a $1500 difference in favor of the Panny. I thought the Sanyo MSRP was around $2700. Yes the Panny is more expensive than the Sanyo, but according to Cine4home it has better color accuracy. There are a lot of reasons why people buy different products. Price may be the biggest, but it isn't the only one.
As for the color chart on the Cine4home review, I can't tell if that is HD or SD. I am glad you referenced this review, because while I appreciate your review judging accuracy by eye is very difficult.
This thread is locked
