Is there any way to turn off 24hz mode on your PS3? If there is, have you tried that? Some people will experience some type of flicker when in 24hz mode.
Originally Posted by GreenMan82
K i will tell you everthing that is hooked to this and by which source also. The ps3 is connected via hdmi directly to the tv, and i have a sasktel hd box which is connected by component because the picture just looks better when connected with it , but that is all that i have connected to the T.V. Now this Backlight flicker only happens on Blu ray and it does say 1080p 24hz in the right hand corner when playing a bd . Now i phoned the place which i had bought the T.V from and they said to buy a clean power supply which they said that might be the problem. Then i phoned Sharp and they said that it may need a software update. I'm not sure which one to try first.
..anyone have any ideas to remove this?
