Originally Posted by
Scott Simonian
And his is tuned around 14-15hz too. That means below Fb it has much less protection down low. Wonder whats worse, the excurson above Fb with 2k or excursion below Fb.
Cause Ive got mine at 11hz and have had no ill effects just yet. I need more power.
Btw, 2k on a LLT has been tested with the TC2k by Illka on HTS. Wasnt that the 320L (?) tuned low clipping at 2k?
I think it was clipping. I am not sure if it has been completely established. I do know that Ilkka is saying the half-roll surround was actually the limiting factor in the 2Ks excursion, so it'd be a different ball game with the tall roll surround. I doubt he'll be able to test that particular sub again, but he may be able to test one of the 2Ks with the tall roll surround in the spring (if he still has them). It was 270liters @ 16.5Hz.
Yeah, but those are Egyptian watts.
No way I'd run that kind of power on WoTW without a serious HPF... 24 dB/octave, dialed in, and tested... that I know will limit the stuff under 10 Hz. Of course I'm pretty paranoid, neurotic, anal, etc., etc.
Yeah, I don't blame you. Even though I am getting a pretty high powered amp for my 2K, I do plan on building Chuck's filter thing-a-ma-jig.
