AVS › AVS Forum › Audio › Audio theory, Setup and Chat › I am really confused on teh best way to set up my new system..help me! :)
post #1 of 3
I have ordered the following:
-Samsung 5271 LCD Tv
-Onkyo 705 receiver (and Onix ref monitor 1 speakers) 5.1 system only. I don't plan on ever doing 7.1
-Toshiba HD DVD A20
-DirecTV HD DVR
-PS3 (for blu ray capabilities)
The Onkyo has 3 switching HDMI inputs, so I will be plugging in my DVD and DirecTV into two of them, if the PS3 has HDMI then that will go as well. The HDMI out will go to the TV.
I'm confused on the HD DVD player though. It has an optical out for audio. Can I use that simultaneously with the HDMI feed into the receiver? Would I even want to? Would I get better sound via the HDMI into the receiver or with the optical? Would my receiver know to use the optical feed for sound if I switch to teh DVD player?
I guess the same goes for my DirecTV HD DVR
should I just use the HDMI inputs only?
thanks!
post #2 of 3
That receiver should take both audio and video over HDMI, so as long as your sources are outputting over HDMI, it should be good to go. You'll also want to use HDMI for things like Dolby TrueHD and DTS-HD, which optical can't handle (although optical will do plain old Dolby Digital and DTS.)
PS3 and HD-DVD player should definitely output over HDMI. Cable box, I'm not as sure about.
post #3 of 3
OK, so pure HDMI is the best... got it. Thanks!
