Originally Posted by
trivista
I am the nut-job who cut a hole in the roof of his motor home to install 3 triad bronze inceiling speakers...they sound great. Now I'm in the process of reconfiguting an old media cabinet for a plasma TV and audio.
The cabinet is in the corner of a large (20'x30' with 15' ceiling) room at the end of one of the long walls. The remining walls are all glass or large doors. It's in the corner because the fireplace is in the middle of that wall.
The speaker enclosure will be 6 feet off the ground and will be about 6 feet wide by 15 inches high. The speakers must fit within the enclosure. My primary candidates are 3 Inroom Silver LCRs or Silver Monitors. It looks like either will fit if laid on their sides. My questions:
Do you have other Triad suggestions?
Which of the speakers above will supply the most sound?
Will those speakers deliver the goods if laid on their sides?
Suggested surrounds?
Do you have any experience with placing the speakers at an angle inside the openings to direct the sound more towards the middle of the room. (The TV will be mounted on a swivel to achieve the same thing.)
I even considered placing ceiling speakers on their sides, but that angle would be too severe.
Any suggestions would be appreciated.
By the way, I have a great Triad dealer but they're just not that into the Triad InRoom products. They're pointing me towards B&W (CT700 series).
Just a wild thought, but what about three InRoom Gold Centers, which are designed for use on their sides? The have vertically-aligned midrange and tweeters.
Actually, the Gold LCR will play louder than either the Silver LCR or the Silver Monitor. At $2,000 each, the Gold Center is fifty bucks less than the Silver Monitor. They are 92 dB sensitive and handle tons of power, which means they will play loudly.
They're designed for horizontal placement.
That room is so live, I'd suggest direct-radiating surrounds; not dipoles. InWall, OnWall, or InRoom? There are many choices.
I'm trying to visualize what you're describing, but I'd leave the three fronts flush with the front of the cabinet. The vertically-aligned mid/tweeter configuration gives you broader horizontal dispersion than centers with side-by-side-by-side speakers on the baffle.
Allow me to say too much about that...
B&W dealers are very loyal. B&W is a great brand. B&W "wants" their dealers to sell B&W all the time, every time. We don't pressure our dealers at all, and we expect them to suggest Triad when it's an appropriate and correct option, and we expect them to sell more B&W, if they are B&W dealers. Triad has been described in print as "the B&W of custom," and I think they hate hearing it, although it's a compliment to B&W. They have even come after us with a new line of custom offerings "inspired" by many of our speakers, including our square, angled-baffle ceiling speakers. We are honored and flattered that they have "emulated" us.
All that said, look at the B&Ws they suggested, and the Triads I suggested, and pick which will work best in your specific application.
