post #2641 of 5157
3/4/11 at 5:16pm
I've used a Gold Monitor on it's side for center, and while it worked great, it's better vertical behind an AT screen. I'm not saying the system will not work with a horizontal center; it will work fine, but three vertical speakers at the same height is always best. As long as the center Gold Monitor isn't close to the floor with the tweeter a few feet lower than the left and right tweeters, you'll be good. The Gold Monitor tweeter, because of the phase plug, has wider dispersion than most dome tweeters, too. You'll be fine. And I'd sooner use a Gold Monitor on it's side for center than 98% of the center channel speakers out there.
I can vouch for that platinum sub being a beast. Physically it is very imposing.
Paul have you got ground plane measurements like this below for the plat? http://www.hometheatershack.com/foru...e-results.html I am suprised that the platinum sub does not get much talk on the subwoofer forum, as it is really well priced and has good output. Will the plat sub change to a 1200 watt internal and rack amp option this year? |
