AVS › AVS Forum › Audio › Speakers › Triad Owner's Thread
Triad Owner's Thread - Page 90
post #2671 of 5173
Originally Posted by Rev75 View Post
Paul how does a silver monitor compare to gold lcr and gold monitor for music and movies?
Because of the 5.25" Scan-Speak mids, the Silver Monitor isn't as robust and won't handle as much power below 150 Hz. Those are the same mids used in the Platinum LCR, but in the Platinum they're crossed over from the 10" drivers at a higher frequency. Silver Monitors work great in smaller theaters where very high output isn't demanded. Also, with a 4"-deep InWall version, they're a problem solver for installations where you don't have the 6" of stud space for the InWall Gold/6 Monitor or InWall Gold/6 LCR. And there's also a great InCeiling Silver/6 Monitor, which may be the best ceiling speaker for LCR use.
The sound quality of all three is comparable, with the Silver Monitor being a little lighter below 120 Hz or so, but the two Gold models play louder and are more dynamic. If you have the room, pick the Gold LCR over the Silver Monitor, which are both around the same price.
It comes down to the appropriate speaker for the application. That's why we have 100 different models.
post #2672 of 5173
Originally Posted by Paul Scarpelli View Post
I'm elated that you like your Platinums, knowing how good the JL Audio Fathom f113 is. But I bet with some experimenting with the low pass slope, I could get the Platinum subs to sound as good (subjectively) on music, too. I've found that when we run our subs 3 dB hot (which almost everyone does, including me), frequencies just above the low pass frequency (80 Hz-160 Hz) aren't attenuated enough, and they appear as boom, fullness, bloom, or a warm quality, making the sub sound almost tubby. I usually remedy this by setting the sub to a steep slope (36 dB), rather than the usual 12 dB or 24 dB, which isn't enough of a brick wall filter.
Another thing to point out is the f113 was $3,700 in 2009 (I don't have a current price), and the Platinum DSP Sub is currently $2,500.
FTW.
I considered the suggestion of setting the slope to 36db that is only available in the Plat's internal settings. The max slop in my processor is 24db. Should I set the subs to 36db anyway? Will that make a difference regardless of the processor setting?
post #2673 of 5173
Thanks Paul that help me make my final pick then. Three gold lcr, two silver surrounds and two gold subs, all speakers in-wall. The three front will be behind a AT screen.
post #2674 of 5173
Most installers recommend doing the high pass only in the processor. I cheat and double up, using the crossover in the processor, and then cascading the sub's crossover on top of that. The result is a steep crossover which pretty much eliminates anything audible above 80 Hz from the sub. Remember that if you're playing at 108 dB and you use a 24 dB low pass, you're going to have 84 dB at 160 Hz. In many cases, that's audible, and it can sound like "boom."
You could start out with 80 Hz in your subs and use a 12 dB/octave slope, just to see if the bass gets "cleaner." The problem is, you'll have to recalibrate the system because you're removing much of that out-of-band upper bass. I went right to the 36 dB slope, as a matter of taste, but also because as an ex-professional musician, I haven't heard that slight added sluggish boom in any life acoustical music.
To sum up, purists will tell you to use the crossover in your processor and move the low pass in your sub to it's upper limit. In practice, I don't often agree with that.
post #2675 of 5173
Absolute killer system! And good choice with the AT screen.
post #2676 of 5173
Let me simplify a little. Leave your processor crossover where it is. If you feel you have too much perceived bass "overhang" (it isn't overhang, but it sounds like it), set the Platinums' low pass to 12 dB and see how you like it. It you want even leaner but still extended and punchy bass, try 24 dB or 36 dB. Again, you may have to kick the bass level up one deeber with the new slopes.
Did the addition of the Silver DSP Sub even things out?
post #2677 of 5173
Note to Tony: Neither Paul Scarpelli or Triad Speakers, Inc. is responsible for structural damage to your home due to use of our Platinum system. Glue down the knick-knacks and buy some Spackle to fix the inevitable cracks.
post #2678 of 5173
I'll give that shot tonight.
post #2679 of 5173
You better believe it! and I love every minute of it.
post #2680 of 5173
Good news for those of you considering Gold or Platinum DSP Subs: Recently, I mentioned that the RackAmp1000 would no longer be available, and that the Gold and Platinum DSP Subs would only be available with the onboard 1,000-watt PlateAmp. Apparently, production of the RackAmp1000 is continuing, and we should have them in stock again by the end of next month. If the situation changes, I'll let you know.
Just for reference, the different versions of the two subs perform the same. The versions with the separate RackAmp1000 are $250 more at retail. The Gold DSP Sub with RackAmp1000 is $2,500, and the Platinum DSP Sub is $2,750. Models with the onboard amps are $2,250 and $2,500.
post #2681 of 5173
This may help some of you when looking at Triad DSP Subs. With a 1 meter ground plane sweep, here are the maximum outputs of one of each of our subs. I haven't discussed max output, but it's good to know:
SlimSub: 105 dB. The InWall SlimSub is only 4" deep, and is made to add some bottom end in distributed audio systems, or with soundbars.
Mini: 108 dB. Good extension and decent output in a very small box with an 8" driver.
Bronze: 109 dB. Good output, small footprint, and response to 20 Hz with a single 10" driver.
Silver: 113 dB. Strong output and extension in a compact sub with a 600 watt amp.
Gold: 119 dB. Approaching brain damaging levels. Add another one and position them less than 4' away from each other, and you can expect 124 dB+ output. But wait, there's more...
Platinum: 122 dB. Add another one for 127 dB max output. What, are you crazy??
Any chance of getting these numbers for the omni subs?
post #2682 of 5173
I'm working on it...
post #2683 of 5173
post #2684 of 5173
Speaking of which, I think I just found the new movie for testing speakers. I don't listen at anywhere near reference levels, but certain scenes in Inception worked my speakers harder than just about any other movie I currently own.
post #2685 of 5173
^^^great movie!! BTW.!
post #2686 of 5173
Thanks, I'll order it!
post #2687 of 5173
Look at the Emotiva site, but they have a special on a 300-watt x 3 (into 4 ohms) Class AB amp right now. Use that with a receiver to drive your four rear channels, or buy their processor. Receivers are usually weak-sauce in the output stages, but the front ends are just fine.
If you don't go with an AT screen, you can do a Gold Center under your screen, but 2nd row listening won't be very good. Do an AT screen if at all possible. It's a big deal.
Thanks for your advice Paul. Also, for this size of room would you consider the Silver Satellites for all 7 channels?
Jason
post #2688 of 5173
Jason
You could certainly do Silver Sats for the four surrounds, but I wouldn't use them for the three fronts, other than in a smaller venue. I would use one of our LCRs.
post #2689 of 5173
As you warned Tony, get the Spackle ready if you crank it up on Inception.
post #2690 of 5173
What do you mean "IF" I crank it up??
post #2691 of 5173
I only have some old Cerwin Vega RE30's (bought in 96, I know) and they shake my room with Inception. I would love a listen with the Plat. subs. We are a Triad dealer, and have several Triad theaters although not Gold or Plat. level but maybe one day.
But I will say I do like the new MicroLCR 3.0. It came with the best template I've ever worked with and I do prefer the grill cloth look over what the Mini LCR 3.0 has.
post #2692 of 5173
I really love the Micro LCR 3.0, too. For $900, a real 3-in-1 speaker for medium-sized flatscreens. The Micro Sat 3.0 is very similar, at $600, and it has about 5 dB less max output. Funny, but most dealers like the much-more-expensive metal grill on the Mini LCR 3.0. It looks (and is) much more expensive, but the main advantages are better sound, and the fact that it can be paint-matched along with the speaker to blend into any environment.
post #2693 of 5173
I don't like it because it's too easily bent so it doesn't sit right on the speaker. You look at it wrong...oops, it's now bent =)
post #2694 of 5173
I like the metal grilles better as well.
post #2695 of 5173
The recent metal grills on the OnWall Mini LCR 3.0 and OnWall Mini LCR 3.0 SE fit much better due to a redesign. I imagine we can also make custom cloth grills if you prefer them, though.
post #2696 of 5173
That depends upon the speaker, the size of the drivers, the output capability, how reflective the particular AT screen is, etc. If you can do a foot, that covers almost any scenario. Platinum LCRs have those two 10" Scan-Speak woofers, so they need to be back the full foot, but a smaller speakier with 4" mids could be closer. My Gold Monitor (center) is about 6" back from my Screen Research screen, and the system measures almost the same with and without the screen down, other than a loss in overall level of about 1.5 dB. (It's not just a treble loss.)
I have an opportunity to replace my Gold Center Classic with a used Platinum center, but I only have 20" between behind my micro perf Stewart Filmscreen to the 1" Theatershield covering my front wall. With the Platinum being 13" deep, I would only have about 1/2 the recommended distance. Would this rule out using the Plat? (BTW, I would continue to use Gold LCR Classics for my left/right channels. Would this be a bad idea?)
Geordon
post #2697 of 5173
Geordon
I think you would be better served finding a vertical center to match your mains. Considering you have a perf screen. Take advantage of it...
post #2698 of 5173
Geordon
I agree with Tony. Even if it's a great deal, it's not right for a variety of reasons. First, as Tony says, you should do a vertically-aligned speaker for center. Ideally, you'd have all three fronts the same, and Classic Gold LCRs are nearly as different from a Platinum Center as is possible.
post #2699 of 5173
Okay, Paul. You have scolded me enough times on this. I will look towards an LCR. Must I stay with the Classic for the center to match my Classic LRs, or can I expand my options with the newer dome-based golds? I currently have Inroom versions, but is there any reason I can't substitute an Inwall (another option in the used market)? I see one advantage of the newer Golds, is that I would get a larger woofer.
post #2700 of 5173
Actually, I haven't scolded you; I just am consistent in my answers. A Platinum Center is wrong for that setup. I'd consider changing to three new InWall Gold/6 LCRs if the budget allows. Tony Grimani still likes the Classic Gold LCR, but we have better products now. The Classic Gold LCR came out almost 20 years ago, and the new ones play about 5 dB louder, have more extended treble, and are far more dynamic. I had Classic Gold LCRs for a few years, and I liked them, but we have much better products now. I'd stay with what you have until you upgrade all three fronts.
  Back to Forum: Speakers
