AVS › AVS Forum › Other Areas of Interest › Car Audio, Video, and Nav › tomtom one 3rd power source?
post #1 of 2
from the specs i have read, it sounds like this unit has an internal battery with a 2 hr useful life. it also says it comes w/ a wall outlet charger. does this mean that there is no adapter plug to power the unit directly from the 12v socket in the car?
another site seemed to indicate that it also came w/ a charger for use in the car, but that again doesn't quite seem like a power source, only a source for a charge.
if anyone can clarify this info, it would be appreciated.
thanks,
Dave
post #2 of 2
thanks,
Dave
i have the tom tom one; it comes with a usb cable to charge it via your computer and a cord to plug into a power point in your car; there as in optional 110volt charger you can purchase separately - mine was included free as part of the deal, but you know what - i have not used it as i use the computer in the house and the battery life is not worth trying to use the unit without a power source unless you are just taking a short trip.
  Back to Forum: Car Audio, Video, and Nav
