AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › hdmi on pioneer kuro 5010 - film mode
post #1 of 13
i've got my xbox360 hd-dvd hooked up via HDMI to my pioneer 5010. i notice when I go into film mode, all the options are grayed out and OFF is selected.
but if i watch my digital cable box, i can select the film mode. i thought this feature was more beneficial for HD sources like blu-ray and hd-dvd.
am i missing something? why is it grayed out?
(thanks in advance.)
post #2 of 13
You cannot select any Pure Cinema mode when using a 1080p/60 signal.
post #3 of 13
so im assuming thats all the xbox hd-dvd player outputs?
when would you want to use one of these modes?
post #4 of 13
480i/720p/1080i/1080p24....all in your manual
post #5 of 13
another question: is there a way to make this movie appear with less black space? i tried the other modes but nothing seemed to work. i feel like this could be stretched "properly" and other DVDs fill the screen.
is this something other kuro owners see? (this is the truman show DVD).
post #6 of 13
Is that an anamorphic DVD?
post #7 of 13
its "Widescreen Anamorphic"
does that mean it wont ever stretch properly?
post #8 of 13
You're suppose to have bars on the top and bottom....not on the sides. You have configured something wrong with your setup.
post #9 of 13
thanks for the reply. could you post your settings that affect image size (not picture quality).
soon as you do id like to test it out. thanks.
post #10 of 13
It's in the manual of your XBox360 and Kuro.
post #11 of 13
i meant your actual settings on your kuro. i couldnt get my kuro to display this dvd properly.
post #12 of 13
I don't have a XBox360.
post #13 of 13
If the movie was played on your HD-DVD player, the most likely culprit for this problem is the setting in your x-box 360.
You have to go to your:
|--System Menu
|--Console Settings
|--Display
you will have to check your resolution and screen format. You may need to enable widescreen (16:9) to output the widescreen movie correctly.
Let me know if it solves the problem?
