AVS › AVS Forum › Audio › Speakers › Klipsch THX Ultra2 System
Klipsch THX Ultra2 System - Page 4
post #91 of 104
Originally Posted by RLBURNSIDE View Post
Hi guys, I just wanted to chime in on this, as I've had a pair of these in a 2.1 setup"
You had a pair of what exaclty?
post #92 of 104
KL-650 THX
I've decided to work on my sword collection for now, so no audio upgrades for me smile.gif thanks for the help anyway.
post #93 of 104
Originally Posted by MKtheater View Post
I will wager you will like them for HT and not so much for music.
Hey MK, your system is KILLER!!!!. Anyway, I was just wondering why you think the U2s are not as good with music
post #94 of 104
Compared to what he had, very high end made for music speakers.
post #95 of 104
I'm considering the following speakers for my 7.1 system. They are listed as THX but not sure if they are "ultra".
Klipsch KL-7800-THX for my front three speakers mounted inwall
Klipsch KS-7800-THX for side surrounds
Klipsch RS-52 II for back surrounds
will pair with a SVS PB12-NSD Subwoofer
Any feedback is appreciated.
post #96 of 104
You could use the KL or the KS for rear surrounds as well. Depending on your seating and room. That way, all your speakers are matched.
post #97 of 104
In my HT I use Klipsch Ultra THX 2
3x Klipsch KL 650 for the front + 4 Klipsch Sub KW 120 behind Stewart Studiotek 130 MICROPERF X2 THX-ULTRA
2x Klipsch KL 650 for Sorround
2x Klipsch Ks 525 Dipol
Room correction with Audyssey MultiEQ XT Pro and you can watch Avatar at 115 DB entire movie without having any distortion, no ear pain after the movie
If you want to beat this system you will have too invest big Money to get a couple of % better
post #98 of 104
Do you use the ks 525 for the side surrounds or the rears? and how far apart do you have the left and right speakers? And what are you powering the speakers with?
post #99 of 104
For the price of the Ultra-2 setup you could do JTR 228's or even 212's across the front, that would easily best the Ultra-2. Actually it would be pretty easy to best them for much much less if you can DIY
post #100 of 104
Well if you you can do a better job by DIY
Then do it!
post #101 of 104
Well if you can do a better job by DIY
then do it!
post #102 of 104
Hi,
In our 11.2 installation (DSX type of configuration), we have 7 Klipsch KL650 THX U2 in the front, and 4 Klipsch KS525 as SL/SR and BL/BR + 2 SVS PB13 Ultra Sledge as subwoofers, this produces an EXCEPTIONALLY involving sound, totally credible with real life dynamic (DTS Neo X 11 Cinema processing, Marantz 8801).
Hugo
post #103 of 104
Originally Posted by Hugo S View Post
Hi,
Hugo
WOW, my mouth just started watering on this set up. Can you post some pictures of it? I would love to see it.
post #104 of 104
Now you can see a picture in the signature, otherwise you can go here, posts 1 to 3 where you can see the various evolutions of the installation.
Hugo
  Back to Forum: Speakers
