AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › LC46D64U power and OPC light blinking
post #1 of 4
I ordered the Sharp Aquos LC46D64U a month ago. It arrived yesterday. I did connect all video/audio cable, and powered it up the first time. The initial setup screen show for a second, then the LCD shut down. The green light of both power and OPC indicator light keeps flashing and will not go off. I have unplugged it several times, waited for 25 minutes to as long as over night, but once I plug it back in, both little green light will not stop blinking. I can not believe that I paid $1400 for this HDTV, wait for exactly 1 month for it delivery. Now all I can watch is 2 blinking green light?
Does Sharp have any firmware or diag software that we can connect to serial port to run a test on this piece of junk?
post #2 of 4
http://www.avsforum.com/avs-vb/showt...hlight=LC46D64
Here is shortcut to a LC46D64U thread from a search by model #.
Maybe someone else has same prob.
post #3 of 4
My husband and I are having this same problem. Can you tell me what happened with your set? We are waiting till the am to call Sharp.
post #4 of 4
Unfortunately, I had the same issue after I did the firmware update. I called Sharp and they told me it had to serviced. The technician came and told me he couldn't even get the picture to come up so he could go into the service menu......alas, bad video board or something. My needs to be replaced.....sorry.
