Originally Posted by
garritynet
Hello,
I have just purchased a 2008 Nissan Versa Sedan S. I want to upgrade the sound but with minimal impact on my wallet.
Ok, so you're concerned about costs. Very reasonable request. Seriously though, you've got to have an aural vision in mind? What exactly are you expecting out of your system? What do you listen to? Anyone can hit a $500 budget, but unless you state what you demand out of your system, no one is going to care what they put in your car.
Standard head-units (aka, OEM) suck. All of them. I've yet to meet one I've liked aside from the fact that they have an 'OEM appearance.' You need to consider a new head-unit. What we're doing here is not simply spending your money, but laying THE foundation of a better audio system. Much care should be taken here. Specs, features, mechanical quirks, and the general concerns about how this thing will work in your ride should be well evaluated. This is the lone piece of equipment you will interact with the most, and the one you will curse the most if you don't make the best choice.
Secondly, you'll need some speakers. Do you know what kind of listener you are? It's my experience that there are two types of audio people: forward & flat. Forward is for the folks who like a bright sound, and flat for those who like the laid-back even sound. Find speakers to match.
Overall fidelity steps up next, and amplifiers are the deciding factor. When the factory head unit's power just isn't enough, or you want better resolution, you need an amplifier. Buy one with plenty of headroom. It won't hurt to over-power your speakers. As long as they aren't taxed with low frequencies they weren't meant to produce, you should be fine. In other words, if you use the appropriate crossover levels and put each speaker in the best position to exhibit its best characteristics, you'll be good to go.
I actually recommend subwoofers lastly. They can improve or ruin a system. Remember the 'Bass Cannon?' Thumbs down. You need to know what your system in a 'full range' setting can do before you opt for more bass, because excess bass is the #1 way to screw up an otherwise tight, clean, & accurate system.
Now that I've laid out the foundation for a good car stereo system, go do some more listening to components.
