Is it possible to wire a speaker via a TV socket on the wall?
I have a sonos system in the basement which is hooked up to ceiling speakers (Speakercraft 2's) and I am thinking of adding a Subwoofer to the system, I would ideally like to feed the signal via an unused TV outlet to avoid adding additional holes etc to my home.
Does this work and will the quality be decent (I know that is a loaded question in these forums!).
I would also like a recommendation for a subwoofer, size etc. My room is about 500 square feet.
My budget is no more than $400, would a 12 inch subwoofer suffice? I was thinking of a 12 inch JBL?
My other concern is that my kitchen is off to the side of my living area, sortof an open walkway, my kitchen is about 200 square feet. Will the sub reach the kitchen or should I install a seperate Sub ?
Thanks for your help.
T.
T.
