Originally Posted by KramerTC
I've had the 59avi for a couple of years. No direct experience with the 79 you just bought but the consensus was (and still is) that the 79 was better than the 59 in analog audio output quality. The video? This is where it gets interesting...everybody that bought the 79 was gushing about this player and then Secrets (www.hometheaterhifi.com) did a review and found a flaw in the video processing. Bam! 180 degree turn-around in people's perception of this player. If you want to see what I'm talking about find the review at Secrets then go find the posts in the 79 owners thread around the time the review was published. Look at the before and after. Bunch of sheep!
There are no direct comparisons between the 58 and the 79 because the 58 is so new. But you can check the Denon 2930 owner's thread and get an idea of the capabilities of the DACs since that player uses the same chip for internal audio. There's a lot more that contributes to the quality of the sound output but at least you have a starting point over there for reference.
The Denon 2930ci use the 1791 chip which is the POC chip (in relative terms, http://www.usa.denon.com/ProductDetails/3262.asp), the 58 uses the 1796, second from the top (1792), the 79 uses the 1738 chip superceded by the 1796 which is superior, the 1738 is about 6 years old. The 79 should sell for less than the 58 on the street. Besides being heavier and having a slightly better output stage it is inferior to the 58 in every other way. The 79 does have iLink for digital output of DVD-Audio and SACD (DSD) to older iLink receivers (they are all going bye bye now). The 58 has HDMI 1.2 so it can output the same over HDMI to the new HDMI 1.3 receivers and controllers that support the formats (not all do, especially DSD).
