Once he has access to the original Pioneer firmware, while keeping the original firmware intact, he adapts features he and/or other MediaTek MT1389 created to work on Pioneer players. If you check out the threads for the DV-578A, DV-588A-S, DV-490V, DV-696AV, DV-46AV, DV-400V, DV-600AV, DV-48AV, DV-410V, DV-610AV, DV-49AV, and DV-420V, you will fully understand how to install his firmware in your players, and how to use your players once it has been installed on them. In most cases, the original firmware can be reinstalled so you won't lose your warranty, except for the DV-46AV, DV-48AV, and DV-49AV. The DV-58AV uses the same firmware regardless of country. So if you need to go back to the original firmware to cover your butt for warranty service, that shouldn't be a problem.
post #691 of 1053
7/19/09 at 2:12pm
